13s on a quarter time??...fook me that was quick!magpie wrote:Danthe does remapped ecu's for m50 inlets and i've got mine on order with him for when i drop the m52 in .penton has this set up on his m52 and it nailed a really good time on it's first outing at pod this year,i've forgot the time exactly but it was good and in the 13's with a strong headwind .
i'm just going to stick with Dan's advice but hope your bbtb doesn't turn into a setback.
cant wait to get my BBTB...
macas
macas
Im sure dan knows what hes doing....rich318i wrote:you need a custom remap to your car not a clone!
What do you call racing cams exactly? And what is wrong with the idle?rich318i wrote:you should try driving a M52 with racing cams bad idle is an under statment.
are you having yours custom remapped ?rich318i wrote:you need a custom remap to your car not a clone!
i'd like to hear the results
+ a yard full of scrap turds
Pentons did a 13.8, which is bloody good for a standard 2.8 engine! Same as my fastest time with the 2.8 iron I built with Alpina cams and raised comp ratio in my chromie a few years agomacas wrote:13s on a quarter time??...fook me that was quick!magpie wrote:Danthe does remapped ecu's for m50 inlets and i've got mine on order with him for when i drop the m52 in .penton has this set up on his m52 and it nailed a really good time on it's first outing at pod this year,i've forgot the time exactly but it was good and in the 13's with a strong headwind .
rich318i
ones with a zero angle (if you that term) and 4000rpm smooth running. but you got to get a custom re-map fact or not???DanThe wrote:What do you call racing cams exactly? And what is wrong with the idle?rich318i wrote:you should try driving a M52 with racing cams bad idle is an under statment.
rich318i
im not mesing about mate. not into guessing just get the job done.. SORTED!!!magpie wrote:are you having yours custom remapped ?rich318i wrote:you need a custom remap to your car not a clone!
