Roof not Folding? Horseshoe not closing?
DaveD
E30Zone Wiki Specialist
Post Mon Apr 25, 2011 8:18 am
its not the fact that its a replacement roof ..if you were like me you didn't replace the tensioner straps so they only half do the job as they are definitely tired...but also have you checked the side wires to see if they are ok ...this can cause problems and you wouldn't know if they were broken
http://www.realoem.com/bmw/showparts.do ... g=54&fg=10
no8 ...it runs through the edge of the roof
William
Location: Home:Suffolk, Uni: Cirencester, Gloucestershire
Post Mon Apr 25, 2011 9:50 pm
I am going to be attempting this solution on mine as have also been living with it for years!
Does anyone know what the function of part 33 is in the diagram linked to above?
DaveD
Post Tue Apr 26, 2011 7:46 am
William wrote: Does anyone know what the function of part 33 is in the diagram linked to above?
It helps electric roof close properly
William
Post Tue Apr 26, 2011 7:41 pm
Thanks Dave, can you explain how? The loop in one end of the rod presumably does something and I'm not sure what/which way around it should be!
Any thoughts appreciated!
DaveD
Post Tue Apr 26, 2011 7:51 pm
the loop holds it to one of the tensioner straps...doesn't matter which way round ...someone made one with two loops (presumably bent it after it was threaded through) good idea as it always seems to move
Petrolthreads
Post Fri Jul 25, 2014 11:42 am
Just ordered a new wire from BM and will be crimping tonight, one question, I don't have the second fabric step shown in your picture, it looks like a cosmetic cover for the main straps is that right?
jmec
Post Mon Jul 28, 2014 12:57 pm
Top banana! Just tried the wire crimp thing and it works a treat, thanks. I always push the bar, second from front, rearward on its over centre link. This seems to work but should that happen anyway?
Petrolthreads
Post Mon Jul 28, 2014 1:44 pm
It does work a treat, the part number for the wire was 54348129978
