its not the fact that its a replacement roof ..if you were like me you didn't replace the tensioner straps so they only half do the job as they are definitely tired...but also have you checked the side wires to see if they are ok ...this can cause problems and you wouldn't know if they were broken
http://www.realoem.com/bmw/showparts.do ... g=54&fg=10
no8 ...it runs through the edge of the roof
Roof not Folding? Horseshoe not closing?
William
- Location: Home:Suffolk, Uni: Cirencester, Gloucestershire
DaveD
- E30Zone Wiki Specialist
It helps electric roof close properlyWilliam wrote: Does anyone know what the function of part 33 is in the diagram linked to above?
William
DaveD
the loop holds it to one of the tensioner straps...doesn't matter which way round ...someone made one with two loops (presumably bent it after it was threaded through) good idea as it always seems to move
Petrolthreads
Just ordered a new wire from BM and will be crimping tonight, one question, I don't have the second fabric step shown in your picture, it looks like a cosmetic cover for the main straps is that right?
jmec
Top banana! Just tried the wire crimp thing and it works a treat, thanks. I always push the bar, second from front, rearward on its over centre link. This seems to work but should that happen anyway?
Petrolthreads
It does work a treat, the part number for the wire was 54348129978
