Although not bought through them..
Not really that excessive Dan.Jhonno wrote:![]()
To be fair.. They are probably a bit excessive, but why not..![]()
294's for the rear as well.. Only a single pot sliding caliper though.
Seperate bell and rotor like I was running with the smaller disc is an option still, but it would be nice to have an OEM solution, plus the CSL disc is a lovely design. Am wondering if the rose joint tie rod would allow me to get away with not using a spacer behind the disc, or at worst use a very thin one..zaust wrote:Might be worth looking a set of separate bells and disks and get the off set for the disk you need.Would rather have the spacer between the dsic and wheel than hub and disc.
