m50 swap progress. from pallet to bay with new pics!!
e30-EVN
Post Mon May 09, 2011 2:39 am
I didn't have a bearing puller lol, so what I did was....
Insert a long bolt in the centre of spigot with the head to the side then jammed another bolt in there to keep the 1st one over to the side to grip the bearing,
Then put a big washer on the long bolt,
Then a nut on the long bolt and then tighten the nut and this pulls the bearing towards you!
The big washer is to sit over the hole the bearing sits in if you get me??... So when you tighten the nut the big washer grips against the hole and pulls the head inside the spigot toward you (thus pulling the bearing) out
Its hard to explain, I hope you can understand my method lol, I made it up on the spot at the time as I tried packing it with grease and using a drift but I had nothing that was a snug enough fit so that didn't work for me. I then came up with the above and hey presto :D 8)
Post Mon May 09, 2011 8:48 am
hulstijn wrote: And do you have a good website with wiring diagrams, because I can't find a wiring diagram of a E34 M50b20 (520i)?
M50 1/ blue/white (dynamic oil level) E30 2/green/yellow
M50 2/ blue/yellw (static oil level) E30 10/blue
M50 /3 red/white (ABS) E30 20/ red/yellow
M50 4/ black/blue (aircon) E30 not used
M50 5/ black/grey (aircon) E30 not used
M50 6/ purple/grey (aircon) E30 not used
M50 7/ black/purple (drive away) E30 not used
M50 8/ grey (engine check light) E30 12/ grey
M50 9/ NC
M50 10/ NC
M50 11/ brown/yellow (water temp) E30 not used
M50 12/ brown/purple (water temp) E30 4/ brown/purple
M50 13/ green/purple(fuel pump) E30 13/ green/purple
M50 14/ black/white (speed) E30 14/ black/white
M50 15/ black/green ( unloader relays) E30 15/ black/green
M50 16/ white/yellow (Rx data) E30 not used
M50 17/ white purple (Tx data) E30 not used
M50 18/ black/yellow (starter) E30 18/ black/yellow
M50 19/ white/green (service reset) E30 11/ white/green
M50 20/ black (engine speed) E30 9/ black
M50 21/ green (ignition) E30 7 green
M50 22/ green/white E30 6/ green/white
M50 23/ brown/grey (oil pressure) E30 5/ brown/green
M50 24/ white/black (fuel rate) E30 8/ white/black
M50 25/ blue (ignition warning) E30 1/ blue
These are the colours from the first one I did, several years ago. There may be slight variations, but this should get you most of the way there.
randomspeedfreak
Post Mon May 09, 2011 11:16 am
M50 9/ NC
M50 10/ NC
might be a silly question but will this be the same on an m52 from a 328 brian?
cheers,
Matt
e30-EVN
Post Thu Sep 08, 2011 11:01 pm
bumping this up to the top for stefangel and anyone else needing advise via pics 8)
StefanAnghel
Post Fri Sep 09, 2011 9:19 am
This is great! Thank you!
e30-EVN
Post Fri Sep 09, 2011 4:25 pm
no worries mate, glad it helps 8)
deanocool
Post Mon Sep 12, 2011 7:38 pm
ive just routed my ecu (m50) under the dash but the loooms a bit short and it sits on the pee. did you have to extend every wire on the ecu loom or just those pictured when the loom is plucked apart? other than that i need to sort out an issue with the clutch slave , finish the exhaust and fan loom and im ready to roll winkeye
e30-EVN
Post Mon Sep 12, 2011 9:43 pm
only a few wires need extending, it will be obvious to you which ones do need adjusting.
piece of advise mate, cut 1 , extend it then move on to the next. they didnt need extending much but my ecu sat right once i was finished :)
