M52 b30 stroker rebuild back on the road
Dezzy
CR24v it's a lifestyle
Post Fri Apr 02, 2010 12:07 am
Just use your pipes Mick. Fit the with your e30 track control arms. E30 pipes bend carefully to suit dead easy. Slowly slowly catchy monkey. :D
Post Fri Apr 02, 2010 12:36 am
got the catchy monkey 8)
Post Fri Apr 02, 2010 8:13 pm
outside temp 6 degrees c with - 10 wind chill factor with mixed in downpours
great! no progress :roll:
Post Wed Apr 14, 2010 10:38 pm
the m42 now looks good enough to plop straight in :)
Post Wed Apr 14, 2010 10:41 pm
told ya it's a good one :D
Post Wed Apr 14, 2010 10:43 pm
Your really going to need to get the yellow crap out of the engine bay now winkeye
while the engine is out do it, you wont regret it winkeye
My engine has a woosh rattle noise now :-x coming back from alnwick today, woooshhs woosssh woooosssh :x the steering coloum is packed with blue tak too :roll:
i either find a low mileage z3 write off or leave it and stick an m52 in
Post Wed Apr 14, 2010 10:47 pm
mr topless your a star :kiss:
Alex stop giving me more Work winkeye
Post Wed Apr 14, 2010 11:00 pm
magpie wrote:mr topless your a star :kiss:
http://cgi.ebay.co.uk/1050W-POWER-HAND- ... 335ae6e353
One of these and use the brush tool, quickest was ive found :D
winkeye winkeye
before
after (the other strut is all white now too )
since that picture i have fitted a white bmw battery and new washer bottle
winkeye :P
Post Wed Apr 14, 2010 11:05 pm
Alex wrote:
winkeye :P
Alex the metal joining piece from the window seal is missing ! winkeye
Post Wed Apr 14, 2010 11:08 pm
e30topless wrote:
Alex wrote:
winkeye :P
I know its on a very long list of "to do" do suppose you have a spare on that fragger of yours that you dont want any money for :o: :P
I decided to put a very thick scratch down thte side of my car today with an e30 seat rail, its a right mess its thick as fook too :cry:
once the cabbys on the road this will get a resto :twisted:
Post Wed Apr 14, 2010 11:13 pm
I have a few I always keep a few of them , they get bent out of shape easily :( will sort you one out :D
Post Wed Apr 14, 2010 11:14 pm
Alex did you try a buffer and some G3 at any point?
Post Wed Apr 14, 2010 11:18 pm
e30topless wrote:I have a few I always keep a few of them , they get bent out of shape easily :( will sort you one out :D
:thumb:
No buffer magpie, i did use some cutting compound but the steam cleaner was easier, used the steam for about 5 seconds in one spot then use the brush bit and it comes straight off, some areas are harder to do that others though
i wouldnt mind touring whore doing me some in silver as mine have gone a bit funny now (my own fault for being lazy with the prep work)
Post Wed Apr 14, 2010 11:28 pm
well he has a spare set Alex as i'm sending x2 rockers and x2 inlets,i'm also sending him a few oil filter caps to finish my set and give him some stock to play with so get your order in winkeye .i may be posting two more rocker covers that i've found on an m42 and an m44 from e36 is' at the local scrappy less than a mile away.i can get a good e36 rack for £20 from one of these cars :D
Post Wed Apr 14, 2010 11:30 pm
8) i want a z3 rack and z3 short shift winkeye
Post Wed Apr 14, 2010 11:32 pm
touring whore (Guy) does a great job his work is great ,
it's bloody hard to find a good powder coating company that cares about the results ...
Post Wed Apr 14, 2010 11:34 pm
The prices seem very reasonable too 8)
Prehaps i should treat myself, i will have a word with him at the teesside meet :)
is it possible to dismantle an IS AFM, as i wouldnt mind that powder coated silver too ?
Post Thu Apr 15, 2010 9:26 pm
i decided to see what was all the noise from the rattler winkeye
so off with the rocker cover and upper inlet, off to powder coat [been wanting to say that for years :chuckle: ]
^ still a nice clean engine :x
then i looked closer at the sprocket teeth :?
now time to check out the chain
winkeye
nice and tight on the tensioner side :wink: time to check out the other side.
to show how shite a none oe chain is,well i nearly got it off the sprocket with a screw driver :eek:
why waste money on cheap engine parts,ffs :cheese: :cens:
the head remains completely undamaged,i guess that's just luck that the chain never snapped. :roll:
Post Thu Apr 15, 2010 9:59 pm
the cam is in a different position to mine
thats bad :eek: very slack
i hope my sprockets are good, a chain and new guides comes out just over £100 from c3 bmw, the sprockets soon bump that up winkeye
bigredbmw
Zone Supporter
Post Fri Apr 16, 2010 8:40 am
making good progress mick .....keeep up the good work ...... my project starts soon .... as soon as the van is sold and get it round to my yard
Kedge
Post Fri Apr 16, 2010 10:06 am
Now imagine what the bottom sprocket will be like, the cam sprockets in the original engine in my old iS were like that but it was on the original chain in 118k miles, the crank sproket was fooooked.
Alex if you changing your chain do the sprokets, may cost more but will be worth it. New chain on old sprockets is a waste of time.
Instagram - Kedge85
town325i
Post Fri Apr 16, 2010 10:33 am
A new chain on old sprockets will cause it to jump the teeth. as a old chain on new sprockets will wear the teeth out
Post Fri Apr 16, 2010 8:01 pm
and all gsf parts for this job are shite do the lot oem parts or not at all!
Post Fri Apr 16, 2010 8:59 pm
what a nice sunny day to get dirty!
got the patient out of the garden for surgery.
got it all ready to remove in a couple of hours and pushed the crane back to mine from the garage as i couldn't be arsed to take it apart and get it in the people carrier.
well it is only a little one winkeye
after a bit of head scratching and jiggling it came out,i had the zaust manifold fouled on the steering linkage and nearly lifted the car up
:mrgreen:
OUT!
my secret weapon a bit from a 6-pot :teehee:
spot the difference
well the fun and games really start tomorrow, Game on turd [again]!!!!!
Post Fri Apr 16, 2010 10:56 pm
looks good but you really need to paint that Tech 1 spoiler winkeye
ps you have a flat tyre :snigger:
Post Fri Apr 16, 2010 11:32 pm
f@ck me Mick, that's a proper crane !! :D
while the donk is out, strip the rest and give it all a lick of paint,
nothing nicer than a clean white engine bay :)
Post Sat Apr 17, 2010 12:05 am
e30topless wrote:f@ck me Mick, that's a proper crane !! :D
Mick tells me the yellow burnt laquer is original winkeye
Post Sat Apr 17, 2010 12:18 am
so is all the muck :D
Post Sat Apr 17, 2010 1:18 am
dug out the engines history,it had a recon head from "the head centre" in pompey [engine from gosport] price of head £465 inc vat + receipts for all the gaskets [head gasket £67] and a gsf chain £35 buit on old sprockets. only half a job then after all that coin spent on a recon head :? 8O no new guides either.
Post Sat Apr 17, 2010 8:25 pm
time to build up the engine i'm using.fitted my plenum with all good pipes,fitted my engine loom,alt,power steering pump and the fly wheel set up with clutch and test fitted the g/box to make sure the clutch is lined up.
my old engine,no slurge around the inlet
the replacement still no slurge :D
finished today with the replacement all ready to fit bar the zaust manifold.
now i'm thinking about fitting the engine,then the box as i i'm working on my own and it might make life easier as i've no-one to let the hoist down and guide the engine in while i'm under the car at the gearbox end levelling the job out etc .
appletree
Post Sat Apr 17, 2010 8:28 pm
Did you take the box out to? or just split it?
How hard was it to get to the bolts??? :D
Got this job to do soon :D
Post Sat Apr 17, 2010 8:36 pm
i took the box out still on the engine,getting at the bolts is what i'm thinking as-well doing it split.
Post Sat Apr 17, 2010 9:32 pm
magpie wrote: Image
Some coont have drove their Jap passion wagon into the back of your car winkeye winkeye
Great progress, get the rent back in the window for next week :D :D
Post Sat Apr 17, 2010 10:42 pm
^thought you were going to offer a hand there so i can get the donk & box in,in one go.
go on you know you want to winkeye 12.00 dinner time is good winkeye winkeye winkeye
Post Sat Apr 17, 2010 10:44 pm
magpie wrote:^thought you were going to offer a hand there so i can get the donk & box in,in one go.
I want to get me interior, wings, and doors bolted to the turd tomorrow otherwise i would have poped up mick :D
