Lee Parkes' E30 Alpina B10.
Chase007
I am getting more and more turned to the idea of this conversion will be watching with great interest Good Luck.
- E30 Zone Meets/Events Team
You know you want to M30 your cab, believe me, it works well in the car.I love mine, so much fun and now the weathers getting better too, hood down and listen to the music from the exhaust noteChase007 wrote:I am getting more and more turned to the idea of this conversion will be watching with great interest Good Luck.
Chase007
Just cant make up my mind if i want a newer engine or whatRav335uk wrote:You know you want to M30 your cab, believe me, it works well in the car.I love mine, so much fun and now the weathers getting better too, hood down and listen to the music from the exhaust noteChase007 wrote:I am getting more and more turned to the idea of this conversion will be watching with great interest Good Luck.
LeonNewton
Looks ace man. Haw and where do you be rightoffs
Yer i am sorry for my bad spelling. i am dislexic and find it just as hard to read your posts as you do mine.
leeparkes
Cheers,I got this from e-bay mate,LeonNewton wrote:Looks ace man. Haw and where do you be rightoffs
leeparkes
Quick update,
ive done the wiring mod on the loom,
instead of messing with the c101 plug(ie pulling pins out)i cut into the loom
i unravelled some of the tape what covers the loom then picked out the 2 wires (white with black stripe & black with purple stripe),sniped and swaped them over then wrapped it back up with insulation tape.
leeparkes
I want to do the rocker the same as the inlet mani and polish the raised bits but i did a test today,painted a piece of metal with hammerite black,left it dry in the sun for a couple of hours the put a coat of lacquer on it,it reacted straight away bubbling,DRIFTBOY wrote:Paint the rocker cover then go over the raised parts with a block and wet & dry, polish those and lacquer it, lovely!
so a word of warning!
DONT put lacquer on top of hammerite!
obviously lacquered is on the right.
DRIFTBOY
Oooh, I feel feel partly responsible for that now!
Sorry!
Sorry!
leeparkes
lol,no worrys,DRIFTBOY wrote:Oooh, I feel feel partly responsible for that now!
Sorry!
Good job i did the test though
leeparkes
Bit of help needed.
Does anyone have a picture of where on the manifold flange it needs grinding down?
Exhaust manifold I take it.If so it doesn't.
Just rotate it 90 degrees so it misses the steering guibo
If i'm wrong then let me know
retroboyo
cant see in the photo sorry how to rotate it, is the a joint in manifold?
leeparkes
Mine looks exactly the same as yours in this picture^ (angle of the flanges)Rav335uk wrote:Exhaust manifold I take it.If so it doesn't.
If i'm wrong then let me know![]()
Are you saying it doesnt need fettling with?
In the picture is it the bottom flange what normally catches? and does it catch on the bottom uj?
Cheers rav
No mate that's how i rotated itIn the picture is it the bottom flange what normally catches? and does it catch on the bottom uj?
leeparkes
Been and took a pic of mine
What do you think??? looks the same angle as yours.
e30_singh
Lol at the kiddo going mentalist on the e34. I have a black rocker cover if you are interested..
leeparkes
Cheers but ive got plans for my owne30_singh wrote:I have a black rocker cover if you are interested..
You will need shades to look at it,lol
e30_singh
Pull out the supersonic angle grinder!You will need shades to look at it,lol
Even if you do get problems, heat up the flanges and rotate.If you read the M30 write up, people are cutting them and then rewelding, why?? i don't know
leeparkes
Heat up and rotate,never heard that one.Rav335uk wrote:Even if you do get problems, heat up the flanges and rotate.If you read the M30 write up, people are cutting them and then rewelding, why?? i don't know
do the down pipes catch anywhere as they go under the car?
One answer to that Lee.
No.
How far u got?
No.
How far u got?
gareth
not so simple... mine clobbered the wishbone lollypop so i had to 'massage' one downpipe a little. i used a M3 system though so it should be possible to make them clear otherwise. not sure what the manifold / downpipe bit of the M3 exhaust looks like, they must have done something there for clearance.Rav335uk wrote:One answer to that Lee.
No.
How far u got?
cireland engineering lollypops will give loads more clearance though
Mine cleared everything , no hiccups at all.
retroboyo
Whats a lollypop on a car?
leeparkes
Done the spray bar mod and checked the valves while i was there,they were all spot on! no adjustment neededRav335uk wrote:How far u got?
Ive sprayed the rocker cover the same as the inlet manifold (hammered black) just waiting for it to dry fully so i can polish up the raised bits.
my order should be here from cotswold by the weekend
new banjo bolts and seals for the spraybar,thermostat hose and sump gasket
Hopefully my mounts will be here tomorrow from beefy too!
leeparkes
It holds the front control arm bushretroboyo wrote:Whats a lollypop on a car?
leeparkes
Bit of an update!
Rocker cover rubbed down and painted in hammerite hammered black,
took 2 days to fully dry
Then hit it with the dremel with a polishing wheel and some megs metal polish,
cant get a good picture but it is like a mirror!
Here's what i used
Delivery came from cotswold today
New banjo bolts and washers (for the spraybar),top hose (little elbow) E28 T piece and the sump gasket
i was bored so i decided to put it all back together and as you all know one job turns into another
Done a bit of plumbing too,i used the E28 T piece and the original length of hose to the heater matrix
Made a cut for the T piece
Then fitted the hose back on and with some fiddling around got it to sit just right so the open end of the T piece is ready to connect to the E30 expansion tank (hope its right)
This is how they come out at the back of the engine,hopefully they should be long enough,i will cut to size when the engine goes in.
Left to do:
SUMP GASKET
Here's what i used
Left to do:
SUMP GASKET
Great work on the paint job, looks awesome mate
Getting there nicely now, bet ya can't wait
DRIFTBOY
Now that is a good looking M30, good work!
gareth
and to think, i was chuffed with lobbing some degreaser over my head while it was off and painting the manifold and rocker cover black...
looking schweeet dude!
leeparkes
Thanks!
i need to find something to bring the hoses and loom wires back to life ie temp sensor wires,top of AFM,plug lead cover,etc....see pic below
gareth
your AFM cover may rub the bonnet sound deadening... mine was removed for this reason
Tep, you'll have to remove the sound deadening.
To bring the hoses back up use WD40, works a treat
don't you know
Well done on the work on the engine, looks the doggies, how long now till it's in????
gareth
bet you slop oil over it when you first fill it
