BMW E30 M-Tech cabrio, V8
PiLLLe
Post Sun Apr 19, 2009 6:27 pm
Niceeeee :cool: It sounds like a monster :twisted:
Btw how will you make your exhaust? Twin pipe with x pipe and one silencer or what?
FormerMember
Post Sun Apr 19, 2009 10:30 pm
Got the exhaust back today from welder but had no time to install it. Also some minor electrical problems have appeared suddenly but nothing too big.
Exhaust is 2x2,5" --> x-pipe --> 2,5" => 2" near rear beam --> silencer --> exhaust tips.
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
PiLLLe
Post Mon Apr 20, 2009 12:54 am
So you're running one silencer?
oze30
Post Mon Apr 20, 2009 1:50 am
mine's running 2x 2 1/4 through an H pipe just under the gearbox to twin singles into 1 backbox and that's verging on loud!
FormerMember
Post Mon Apr 20, 2009 6:09 am
Yep, only one silencer.
My friend's E30 V8 is running on one silencer also and it sounds really good, not too loud. Though, the silencer is custom made..
But we'll see, first i've to sort out this electronic bug (my ECU doesn't turn power off when you turn ignition off)..
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
oze30
Post Mon Apr 20, 2009 6:28 am
Unloader Relay?
mike_sayer
Post Mon Apr 20, 2009 9:00 am
Only just seen this thread - and i'm green with envy! Incredible work...hearing that noise for the first time must've been very rewarding. Awesome.
"And if you are clinically insane, by which I mean you wake up in the morning and think you are an onion, here's your car." - Clarkson
UweM3
Post Mon Apr 20, 2009 9:20 am
citizensnips wrote:alright
having trouble with my brakes as i cant get the left hand drive 540 master here, wondering if i can use master with no servo,
is your ecu going to live under the dash or in a box i engine bay like the 540?
whats the stuff in the battery tray? abs?
anyway i digress, which fuel pump are you using?
looking very good by the way,
I am planning to run my car without servo. I have changed the pedal ratio to increase force. So far it feels ok with not too much pedal travel. but I haven't driven the car yet.
S38B38
Post Tue Apr 21, 2009 12:17 am
It can give trouble when going sideways 8O
Sveinbjörn Hrafnsson
E30 CABRIO M70B50 V12 5lug
ALPINA B10 BITURBO 346@507
550 V12 JML Motorsport
oze30
Post Tue Apr 21, 2009 11:06 am
How?
Jon_Bmw
Dangerous when thinking
Post Tue Apr 21, 2009 11:22 am
Most people don't really brake when going sideways...do they? 8O
PiLLLe
Post Wed Apr 22, 2009 3:29 pm
Jon_Bmw wrote:Most people don't really brake when going sideways...do they? 8O
Panic mode..... yes they do :mad: :D :D :D :D
S38B38
Post Thu Apr 23, 2009 3:28 pm
oze30 wrote:
How?
Drifting i mean ,, not as easy if you dont have servo
oze30
Post Thu Apr 23, 2009 4:00 pm
depends on the ratio. I've got a 5.5:1 pedal box, so it should be better. PLUS, I'll be runnign 4 pots, so it will be fine!
citizensnips
Post Fri Apr 24, 2009 10:35 am
i've now chopped a lot of my battery box away and a hole in the bulkhead, so i'll have to put the master there now :) , e30 was tad large and didnt like the fit so i've got a golf mk1 one coming and my mate has a ford ka servo which i'll try this weekend
what radiator you using jonsku? the e30.de site appears to say the e34 v8 radiator fits but offered mine up and its far too wide. how much did your custom one cost oze? its either a trip to scrappy with a tape measure or a call to allisport
also oze do you have an electrical connection diagram for the engine plug pins, i've got 3 now and none agree with each other fully :D , tried in vain to find a pin out for e34 engine plug
Jon_Bmw
Post Fri Apr 24, 2009 11:55 am
Is yours a manual or auto rad? Perhaps that is the difference in size?
I have a manual e39 rad I could measure, but that might be bigger than an e34 manual rad??
citizensnips
Post Fri Apr 24, 2009 12:26 pm
its the manual rad i have, no harm in measuring yours if its not too difficult, its width was the problem height and depth seemed all good
Jon_Bmw
Post Fri Apr 24, 2009 1:04 pm
The widest plastic part is around 760mm
The 'metal' of the rad is 675mm in diameter.
The end tanks seem to be bigger at the top, but as the rad is on the car, I can't really measure lower down...
HTH.
oze30
Post Fri Apr 24, 2009 7:21 pm
Right. It's going to cost roughly 200-250 to get the rad made up.
E36 Big 6 aircon rads will fit, plus i think you can use the header tank on the rad. E34 non V8 air con rad SHOULD fit, but the V8 rad is way too wide. I don't know if you will be able to fit the servo where the battery tray is. You might be able to fit the E36 pedal box, I'll give this a go sometime next week when I can get to my scrapper. If it fits, I'll be hugely happy as it means you can still get the servo assist!
The setup i used. Twin M/C under the glove box.
FormerMember
Post Fri Apr 24, 2009 10:09 pm
I'm using E28 535 radiator, which fits straight on without any modifications. That's the one germans use so it should be enough.
Friend of mine has E34 V8 radiator but he needed to modify the E30 body a bit to make it fit.
Here's folder where you can find my C101_X20 schematics. ;)
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
FormerMember
Post Sun Apr 26, 2009 7:38 pm
Alright, solved the electrical problem with help from a friend :)
Tried the exhaust on but i've to modify it a bit, also still don't have brake discs and intake tube is not finished. But otherwise this cabrio is almost ready :P
And rest of the pictures here.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
oze30
Post Sun Apr 26, 2009 8:08 pm
Just wondering, does the bonnet close with the brake servo so high up?
S38B38
:cool: :cool:
STUNNING
The_Diddler
Love it up the more door !
Post Sun Apr 26, 2009 8:13 pm
Oh my.........................................................................
FormerMember
Post Mon May 11, 2009 7:35 pm
All kind of little bits and parts are bolting to the car every day so it starts to be quite close to "ready".
Interior is almost all in, engine bay starts to be ready etc etc.
Next weekend i'll get few parts from TIG-welder and couple of mufflers to my new exhaust system so i'm hoping i get coolant in the engine on saturday - sunday so i can keep her running for a while :)
Brake discs are on order and should arrive next week, so test drive could be in only two weeks.. Yikes! :D
oze30 wrote:Just wondering, does the bonnet close with the brake servo so high up?
Test-fitted the bonnet once again yesterday and there were no problems with it :)
Coolant reservoin is really, really close, though.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
twism
Post Mon May 11, 2009 8:20 pm
Can't wait to see new clip, and hear her running :twisted:
JohnnyT
Post Fri May 15, 2009 12:51 pm
I can't wait to see this thing finished. The car was already awesome to start with, the V8's just adding to the package.
Barx325i
Post Sat May 16, 2009 12:27 am
a dab of left can make all the difference
FormerMember
Post Sat May 16, 2009 9:41 pm
Thanks guys :)
Got the engine bay ready except all the panels (probably gonna bolt them on after this post :)). Interior is in except seats.
Tomorrow i hope i get exhaust done and coolant in the engine. On next thursday i might be driving this thing. :cool:
Anyways, those pipes don't suit very well the OEM-look i'm going after :( Well, now i've something to do next winter also :D
More pics here.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Post Sun May 17, 2009 3:43 pm
That looks factory, like it just rolled off the production line :cool: :cool:
320ise
Post Thu May 21, 2009 2:32 pm
+1 it does look factory and awesome!
oakey
Post Thu May 21, 2009 5:45 pm
Like a glove! :cool:
robbo86
Post Sat May 23, 2009 2:17 pm
Wow...... I hate people like you! Only because you have it and I havent :(
Nice looking conversion though. Well done!
FormerMember
Post Fri May 29, 2009 9:59 pm
Thanks!
Something good and bad has happened..
Good thing is i got the brakes last week and finally had some time to test them. And damn they look good :)
The engine bay looked good also but i had to take the engine out once again because left exhaust manifold leaked :x :x
So right now the engine is sitting on the floor and i'm wondering how i can fix the exhaust manifold once and for all..
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Post Fri May 29, 2009 11:32 pm
Sorry to hear that mate.
But atleast you have found it now rather than later. :cool:
