SuperCharging an M42-Opinions? Whats needed?
deano325t
Post Sat May 14, 2005 10:09 pm
you can route the brake vacuum and rocker vent to the other side of the blower ..(the suction side) if its a problem
my rocker vent goes to just before my turbo
Dean
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Sun May 15, 2005 10:54 am
cheers lennie, always like to makesure I understand these things. so here's another question... anybody...
What exactly do the pipes to the servo do? and what sort of pressure or vacume are they designed to work with? I'm just wondering when, why and whoch way they operate. sorry I'm an engine n00b :)
Turbo-Brown
Boost Junkie
Post Sun May 15, 2005 12:16 pm
The hose to the servo should only see vacuum which is supplies to the servo.
If you're pressure charging an engine, there should be a one way valve installed in the hose which lets air from the servo travel to the engine, but not back again (when under boost)
Lots of cars seem to have a one way valve installed anyway which I believe is to safeguard against oily fumes finding their way into the servo and perishing the diaphragm.
EDIT> Hmmm, thinking about it, if you connect the vacuum hose inbetween the throttle and the supercharger (the charger's downstream of the throttle with the eaton's isn't it?) then you'd always have a vacuum, even when the compressor bypass valve's open :)
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Sun May 15, 2005 12:48 pm
Thanks turbo-brown. I'm with ypu up until the edit but then I lose you. If the vacume hose is connected between the cahrger and throttle, i.e moved from behind to infront of the butterfly if I understand what you mean.. wouldn't that mean pressure would be applied to the all the time and never vacume?
Turbo-Brown
Boost Junkie
Post Sun May 15, 2005 2:13 pm
Aah, don't think I explained it all that well :(
What you have is:
Air filter-----Throttle body--*-1-Supercharger--2--Engine
So the air comes in through the filter, you meter it into the supercharger with the throttle, the 'charger compresses the air and supplies it to the engine.
Now if you connect the vacuum hose to the bit with the *, you can see that it's on the side of the 'charger that's being drawn from, not blown to so it always sees a vacuum.
Now the bypass valve is connected at points 1 & 2 and typically is operated by a vacuum in hose 2 so that when under light load or when the throttle's shut, the compressor's bypassed. This means that normal engine vacuum exists in hose 2 all the way back to the throttle body and so at point *, there's still a vacuum to operate the servo :)
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Sun May 15, 2005 6:15 pm
ah ah, now I see, it was my error. I always assumed that the throttle body was on the exit of the charger.
if this is the case does the maf also go before the charger?
I always imagined
filter -> charger *-> maf -> tb ** -> engine
* some kind of blow off valve
** brake vacuum with one-way valve
It seems this is incorrect?
I'd not considered a light load bypass system.
cheers.
Omi
Witty custom rank.
Post Sun May 15, 2005 9:40 pm
How did I miss this until now?!
Can I please be added to the list?
I'm going to have a spare iS to play with, so I can try this and/or a turbo before going ahead with putting it on the road car. Should be easy enough to put a user-guide to it at the same time too. :)
...or is it?
E30Mark
Post Wed May 18, 2005 7:52 am
Omi wrote:How did I miss this until now?!
Same here, how long has this thread been going.... i've had my head stuck in the sand too long!
Is it too late to jump in???
PM for details
SwirlyE30
Post Thu May 19, 2005 6:01 pm
Just to update. I may be up for doing this on my new is engine going in soon, do people not think that more than 170bhp is achievable? I thought the mini superchargers were good to up to 200ish.
Anyway on getting 200! Maybe using two :cool:
1986 Chevrolet Corvette. 330ftlb torque....V8s rule!
SHAKEELE30
Boost Junkie
Post Thu Jun 02, 2005 2:49 pm
will the mini supercharger fit on a e30 325, if so how much is it for the turbo, is it difficult to put on. what else would be needed to fit it on.
frosted
Post Mon Jun 06, 2005 12:20 pm
note- still on. will update when i know from my mate how many he has aqquired.
regards,
frosted
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Tue Jun 07, 2005 10:36 am
:rock: sweet dude :)
320Touring
Post Tue Jun 07, 2005 12:30 pm
:banana: :bling: :clap: :thumb:
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Thu Jul 21, 2005 11:05 pm
hey frosted mate. was talking to 320touring today about the m45 and just thought I'd ask how things were lookin????
frosted
Post Thu Jul 21, 2005 11:45 pm
yeah good mate. current standing is at 6 i belive. mates been away for a few weeks. back end of month and then were gonna sort it all out.
soz this is taking so long plp!
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Thu Jul 21, 2005 11:53 pm
no need to be sorry man. cheers for the update! sounds like things are very :cool: !!!
:rock: I can feel the boost already :)
Demlotcrew
Post Fri Jul 22, 2005 9:08 am
Looking good dude!
A
320Touring
Post Mon Aug 08, 2005 12:24 pm
frosted wrote:yeah good mate. current standing is at 6 i belive. mates been away for a few weeks. back end of month and then were gonna sort it all out.
hey frosted, any more word mate????
cheers
neil :cool:
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon Aug 08, 2005 4:49 pm
mmmmm supercharger :)
Russ
Post Tue Aug 09, 2005 5:50 pm
So has anyone actually recieved a supercharger yet? Its been 4 months now!
No one was actually niave enough to believe you were going to get them were you?
:lol:
318iS became MR2 Turbo became FTO GPX Mivec became Impreza became Rover 620Ti became Honda S2000 (current) became Fiesta 1.25 and 200SX Drift Slag (when the Honda has gone)
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Tue Aug 09, 2005 6:27 pm
Russ wrote:So has anyone actually recieved a supercharger yet? Its been 4 months now!
:lol:
I live in hopes.
I'm not ready to fit one yet anyway as I've got other stuff to get so if one turns up for free then all good. if not then it's not the end of the world. but as they say you gotta be in it to win it.
frosted
Post Wed Aug 10, 2005 11:09 am
since im running 3 full time businesss as teh moment how does "go fu*k yourself sound russ" sound?
im still waiting on my mate to check there all ok and packeage em so i could send them out. hes having to be carefull becuase he does not want to lose his job over it.
Demlotcrew
Post Wed Aug 10, 2005 11:21 am
I dont mind waiting, the guy is doing us a favour and its on his time scales.
Frosted, dont worry about russ he has a sense of humour that requires some adjusting to understand. I wont say anymore. :screwy:
A
frosted
Post Wed Aug 10, 2005 11:23 am
grin, yeah im not really bothered. doing coldfusion with a client on the phone yelling at me and then reading that i was like DAMN IT!
:lol:
Demlotcrew
Post Wed Aug 10, 2005 11:27 am
frosted wrote:grin, yeah im not really bothered. doing coldfusion with a client on the phone yelling at me and then reading that i was like DAMN IT!
:lol:
Well hes only a little guy so you can say what ever you like, hes not going to do shit about it!
A
Russ
Post Wed Aug 10, 2005 11:33 am
Just pointing out that it seems very unlikely that the event would happen. Why on earth would "Your mate" give these away when he could get Ԛ£150 each for them if he flogged them on Fleabay?
Demlot how about you stop being such an arrogant prick? Its really easy to play the macho man whilst hiding behind the keyboard.
Dont say things on the forums that you wouldnt say to my face.
Demlotcrew
Post Wed Aug 10, 2005 11:38 am
Russ wrote:Dont say things on the forums that you wouldnt say to my face.
Post Wed Aug 10, 2005 11:47 am
Play nice guys....
Or i'll come and knock your heads together :tongue: :poke:
Russ
Post Wed Aug 10, 2005 11:54 am
He started it! ;)
frosted
Post Wed Aug 10, 2005 1:17 pm
funney shit
wel without sounding like a twat, prob will anyway :cool:
150 a pop WOW! dont really mean fu*k all to me considering i charge 500-1000 A day for what i do. plus the time it takes to sell on ebay not worth it. plus they were free and im not a cu*t.
people making comments like ur self and i can understand why people would think sod it ill sell em them.
Russ
Post Wed Aug 10, 2005 2:10 pm
I'll resist the easy rent boy jibe! :D
frosted wrote: plus they were free and im not a cu*t.
I never called you that. Selling something wouldn't make you, as you so eloquently put it, "a c***"
This mate of your is supposed to have "loads" - so 10 chargers @ Ԛ£150 each is hardly to be sniffed at is it.
frosted wrote: people making comments like ur self and i can understand why people would think sod it ill sell em them.
eh?
frosted
Post Wed Aug 10, 2005 2:13 pm
thought id help a good forum which has given me ooooodels of advice.
1500, not be sniffed at. but hardly mega bucks. not as far as im concerned anyhow.
anyway dont have time for this crap :D
will msg again when it all done.
320Touring
Post Wed Aug 10, 2005 2:58 pm
Russ and frosted, chill :cool: :D
Russ was being funny, and TBH the joke prob didnt come across just right
frosted, I can understand that your mate is trying his best for us, please pass him my thanks!
and also can I thank you for organising this :D
we gotta be one big happy family :group:
Russ
Post Wed Aug 10, 2005 3:16 pm
frosted wrote: 1500, not be sniffed at. but hardly mega bucks. not as far as im concerned anyhow.
Wow, your mother must be so proud.
320Touring wrote: Russ was being funny, and TBH the joke prob didnt come across just right
I wasnt actually, I was being perfectly serious. Just seems like a long time for this plan to come to fruition.
If it happens, all well and good, just doing my bit to speed things along!
frosted
Post Wed Aug 10, 2005 3:22 pm
no im proud. all self made.
and you really seem like a bloody idiot who is trying to wind poeple up for no reason. cant leave it have to put another post?
4 months not really that long considering he has to be carefull when "aqquiring" the chargers from his work. plus not every bloody mini has the upgrade so it takes a while to get a decent number together.
hurrying up? no relevence to you at all this thread. not planning on using one on the mr2 are you?
