gaz fully adjustable front and rear coilover[new buy 07/05/]
				Trise30rally
I had some on that old 316 of mine are they the same size? otherwise a mate of mine has broken a few 325's so he will definately have some spare....
				BadDave
When I sent mine back for rebuilding,it only took a couple of daysmikekean wrote:so wats the turn around on sending them your struts and you getting the finished product made. i share a workshop with my brother and my working area is infron of the door so the car cant be laid up for more than a 2 weeks really as he is also building a rally car and needs to be able to get it in and out the shed.
Will obviously take a little longer to add the threads and adjusters to the strut bodies
I was well impressed with there customer attitude and turnaround time
HTH
Dave
Alpina B10 3.2L  #187 (1 of 64 brought into the UK)
I've got the Gaz coilovers and the only strengthening mine has on the rear towers is a strut brace (whch is effectively Z3 plates with a bar between them).benjy wrote:And on this point you are absolutly certain??? Do you have a pic of these Z3 plates?UweM3 wrote: Fit a Z3 plate and all will be fine.
I'm still uncertain, this is a lot of money to shell out in one hit, not that i'm slagging! It looks the mutts nutts![]()
Do GAZ require a pair of struts first or is there a surcharge?
Cheers,
No problems so far and I've done 2 trackdays and about 2500 miles (some of those are on very poorely surfaced antqiue Roman roads).
ahh balls to it ill have a set  - if there is a
reasonable deadline for sending the old struts off ?
are the top mounts you offer the adjustable ones
i will need to do some reserch into the spring rates i need so will need to wait till that is sorted but i think it should not take to long
can you give me a buz on 07866845511 please thanks
				Karan
i also want a set of these but will be calling to discuss spring rates for my car (heavy engine), and also are the front top mounts camber/toe adjustable?
also for reference, have you got a contact there who i can talk to and what is ure name again mate so i can quote you please
how many peeps so far? need these asap, car handles like a pissed pig at the moment
- Beemer Redeemer
 - Contact:
I'm registering my interest on these.
I have just disassembled my front struts ready for sending to Gaz anyway so a group buy seems like the sensible thing to do.
Might be wrong here (so please correct me if so), but i think you need to send the 51mm struts to be used rather than the 45mm struts.
I am building my E30 to enter in the PBMW cup (starting end of March). I just need to check if we can run coilover rear suspension as most of the competitors cars ive seen have been the shocker and separate spring affair.
As agreen has said, i will just need to look into spring rates. But i'm provisionally in.
Can we definitely confirm they are coilover rears ? Cheers.
1. Trise30rally- race/rally setup
2. mike - rally setup
3. agreen (provisional)
4. Karan (provisional)
5. Beemer Redeemer (provisional) Race setup
6.
7.
8.
James
6.
7.
8.
James
6.
7.
8.
what he said prov !!!
but need to speak about spring rate options i have been advised of what to go for and will take his advice and want to see if you can do them and
also need to check top mount specs , and clearence issues
Need contact number !!!
6.
7.
8.
				Trise30rally
Ok we have 5 now lets go
						no three are porvisional we (i ) need more info before we go rushing into it as state baove they say provisional next to them !Posted: Mon Feb 11, 2008 11:00 pm Post subject: Re:
i have had no contact yet from the guy rganising this but i am iin no rush to rush in i want to check they have the correct spring rates etc as i am sure the other do to
so wee need a number >?
				Karan
yes i need to confirm rates and any rear turret/wheel issues
also need to know the nature of the front top mounts and if they are camber adjustable
can someone please shed light on this as i would like these sooner rather than later
				gareth
i'm not after any as i have ledas already but a point to check with GAZ...
Do they clear the fuel breather pipes etc that run through the offside rear arch? the ledas don't so at present, i've still got my old pigtail springs on and have removed the springs from the rear coilover bodies. i think the pipes will need re-routing inside the car or something...
hi mate sorry not been on been buisy.it would be best if you phone gaz direct as dave was originally half owner leda until he brought out.gareth wrote:i'm not after any as i have ledas already but a point to check with GAZ...
for personal reasons i wont discuss.
as for the rest all i said is i need five to go ahead.
if you all pm me your details then i pass them onto dave.
he will contact you all and awnser all questions on spring rates etc.
you are still not abliged to buy until your happy with what your getting after that.i only needed five to get ball rolling not to hand over any money until you all been contacted by gaz shocks direct.are we clear now.
				Karan
hello dudeoze30 wrote:I'll go for it.. as long as we can work out some spring rates for the ass end of a touring with a 55l LPG donut and an M60 in the front!!
prob go for same as mine: 600 front 300/350 rear
should be a good starting point and if necessary you can change from there. Those rates are track biased, even though mines a daily.
				Karan
hopefully there will now be some sweet handling e30s in the world after this!MJG wrote:MOFO! That is perfection. Don't have the money yet though - poo! I was unaware of true rear coilovers being available. I will save my pennies for a set, hopefully the group buy will still be on! Brilliant.
ohh right cool ill list them up for sale then ! thanks i just deffo wanted to know i did not need themthe gaz coilovers have rose jointed top moounts already on them so u wont need ure rogue ones-sell them
so do i need to buy some e36 cab ones to send away ? with the struts cheers karan
				gareth
i'm not going to call him, i'm not looking to buy any! just thought it should be checked / considered by anyone looking to buy a set as it'll add a load of work to fitting them.elf wrote:hi mate sorry not been on been buisy.it would be best if you phone gaz direct as dave was originally half owner leda until he brought out.gareth wrote:i'm not after any as i have ledas already but a point to check with GAZ...
If this GB is still on then I am definitely interested.  However I have run LEDA coilovers in the past on my E30 race car and the rears did catch in the arches.  I want to be sure that this won't happen with the Gaz GGA units as they are going on a road/trackday car this time and I want to keep it a little more civilised.
Elf - I'll send you a PM with my details and would really appreciate a call from someone at Gaz to confirm spring rates and potential clearance issues etc. If that all checks out OK then I'm in and I'll get the IS on stands.
6. ppcsam - (track day spec)
7.
8.
7.
8.
just need mikes details
and trise30rally details then i can give them to dave to
contact you all direct for specific needs etc.
and any other questions you have.
i have pm them both so if anyone can give them a nudge
as some people want these sooner than later
regards gaz.
regards gaz.
3. agreen (provisional - Track day spec)
7.
8.
thanks for every thing elf,
i know this seems like alot of hard work as your are getting nothing out of it but we are all trully greatfull i am sure , cheers elf
7.
8.
ok mate glad you appreciate it.agreen wrote:1. Trise30rally- race/rally setup
7.
8.
still waiting for
mikes and trise30rally
anybody know them to contact them as some want asap.
i have pm them both
