how can i tell if 95 m3 will have ews
irish320i
Post Wed Jan 30, 2008 2:21 pm
any help would be great sorry for all the questions just don t want to miss out on this engine if i can make it work Thanx
jmc330i
Post Wed Jan 30, 2008 3:26 pm
E36 3.0ltr M3s from Jan 95 will have EWS, the earlier 94 models dont. All 3.2 Evos have EWS.
James
'91 325i Sport
'93 318i touring 16v
bobafett
Post Wed Jan 30, 2008 3:34 pm
Colour of the key blade too, if it has a silver blade then no EWS, if the blade is gold looking then sorry dude EWS is fitted......hope this helps.
What ?! Drive straight officer......It's an E30 !
It's the Ultimate Drifting Machine.
irish320i
Post Wed Jan 30, 2008 3:45 pm
thanx sorry will i have to get the box with it or will a e36 box work under pressure to let him know sorry again about this
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
Ant
Retired Team Member
Retired Team Member
Post Wed Jan 30, 2008 5:10 pm
S50B30 is ok with all the 6 cyl 5 speed ZF boxes so 323/325/328 is fine.
if you meant the EWS box, then you'll need all the EWS gubbins, the key and the ring antenna
HTH
jmc330i
Post Wed Jan 30, 2008 6:53 pm
Ant wrote:S50B30 is ok with all the 6 cyl 5 speed ZF boxes so 323/325/328 is fine.
E36 323/325 Getrag boxes are slighty smaller and lighter than the ZF box and have a different output flange for the prop IIRC, meaning the E30 M3 prop wont fit so an E36/E30 combo is needed for the conversion. I think the 328i box is the ZF, same as the M3 5spd.
James
'91 325i Sport
irish320i
Post Thu Jan 31, 2008 2:11 pm
thanx for all he help lads i have a e34 525 box aswell which is a bigger zf boat least i know the 325 box will fit can get the shaft sorted without too much hassle hopefully.
James did you have any problems with the engine itself what should i look out for on it
Al
