video posted of my problem ... help
wks79
Wed Jan 30, 2008 9:12 am
car's been acting like this recently ...cant figure out what's causing it to misfire like this .
Image[/url]
http://s223.photobucket.com/albums/dd25 ... V03998.flv
anyone help ? ...seem to misfire every time i let go of tthe throttle after high rpm ...(2 ~ 3k rpm ..) .... mmmmmmmmmmm
jcjdavis1
Wed Jan 30, 2008 11:05 am
Hi sorry I can't help,but I wished mine sounded as good as that. :)
WerkdE30
Wed Jan 30, 2008 11:18 am
thats not a misfire thats a back fire.
if its auto put it in drive then put your foot on the brake and rev it up. if it goes like duh duh duh its misfiring. if it runs smooth its not. if its a manual heel and toe it to do the same.
sounds to me like its just your exhaust popping because of your back box. unless you have had the exhaust for a while and its just started.
after i changed the exhaust on my nissan motor it sounds like that when you give it a good rev. sounds cool tho.
wks79
Wed Jan 30, 2008 11:41 am
hahah ..its cool for a while i guess.
i've had this exhaust for less than 2months... i dont think itd be the cause of the distinct sound ..mm .
standard Remus sports backbox thats all.
does it sound like a vacuum leak or ..?
anymore ideas? cheers. :x
WerkdE30
Wed Jan 30, 2008 11:45 am
does it run badly at idle?
wks79
Wed Jan 30, 2008 11:49 am
at idle its fine really ...with the airconditioning on...its bout 900 -1k rpm.
well its definitely backfiring ..as u put it. coz when accelerating ...im not getting any pops or jerks from the car...
just this backfiring when i let go of the throttle...its seems fine if i cruise at 2k rpm ...
the point of rpm that seems to cause most of the sound is mainly round 3.5k down to ...say 2k rpm .
anywhere below or above that on the rpm meter ..it sounds fine.
just need to knwo whether is this sounds like a prob? or its just an exhaust thing that happens ..
WerkdE30
Wed Jan 30, 2008 12:00 pm
if it was a vac leak id say ur idle would be affected.
i dont think its a problem if the car is driving fine. unless it iritates u i wouldnt be too worried. i like a little pop pop.
all my cars do it. but then again they all have "chav" exhausts.
WerkdE30
Wed Jan 30, 2008 12:02 pm
are those wheels a strait fit or so u have spacers?
wks79
Wed Jan 30, 2008 12:10 pm
they're just normalset of Borbets ...
it fits straight in .
15"
daveburke114
Wed Jan 30, 2008 12:17 pm
yeah sounds like that on mine too with a stainless steel exhaust.
isnt it when you lift off, the exess fuel gets burnt up in the exhaust causing a pop, same as when you see flames coming out he back of a rally car's exhaust?
i could be wrong tho!
wks79
Wed Jan 30, 2008 8:59 pm
its more of an audible prob than an engine prob ...i hope.
flames ? :) sadly no flames here.
cypriot_boy_2k7
Wed Jan 30, 2008 9:04 pm
its the backbox, my remus used to do that, now got a powerflow
wks79
Thu Jan 31, 2008 7:35 am
so is it possible to have an exhaust shop take a look at it and repack the fibres in the box?
know of a place that does exhaust for high end sports cars... and also very good at replicating exhausts of any kind (eisenmann, remus , supersprint)
btw im in Kuala Lumpur, Malaysia :D
cypriot_boy_2k7
Thu Jan 31, 2008 8:42 pm
why what wrong with it?? :?
1an
Thu Jan 31, 2008 8:46 pm
i want my m20 to do that, hmm remus back box then :twisted:
have you got the centre section in there? or a tubi manifold, i wouldnt worry about it mate
wks79
Fri Feb 01, 2008 5:32 am
the centre section is the flat type ...
everything else is stock standard .
