Conversion for the convertible: M30 it is! DONE!
jaffro
which lead do u mean? is it not part of the m30 loom?
Ziggy
Starter motor -> battery... on an E32 735i the battery terminal is on the opposite side to an E30 - a lot closer to the starter motor!
Scooter318
Has anyone performed this swap on an M10-engined 318i? I'm just curious how different it would be from starting with a six-cylinder car.
ric325i
scooter i did it and its fine.
you should upgrade the suspension as the 4pot springs wont take it. you will need a header tank if its the late engine but thats it really.
Ziggy, the wire from starter to battery is very short on the e34 but it just fits. good luck man.
Ziggy
No chance with mine - it's about a foot short! & Mark thinks he's probably not got one, so I won't have a chance to get one until I can get to a scrappies, which won't be until Fri at the earliest. Bother.
jaffro
ive got a 325 battery lead will that do ya?
Ziggy
As in battery to starter motor? I'm almost certain that a 325i one would do, but I left mine attached to the old engine when I sold it! So the new owner now has 2 of them as he was replacing another 2.5.
Ziggy
Just a thought - anyone know what your average motor factor would stock in terms of long earth leads? Can't imagine there's much need for them tbh...
ric325i
i like the idea of a m20 one! but it still maybe too short?
i had my battery in the boot but since i was not using it much there was not enough power to run down the long lead from the boot!
Karan, Gall is having starter issues with his at the moment so i have passed the info on to him. it could be really useful!
ziggy,
patience man. this does mean you could have it running by the weekend!!!
Karan wrote:the starter signal for the solenoid from the ignition is prob too thin and not givving the sloenoid enough beans to push open try running a thick wire and touch it on the small connection on the bottom which has a 10mm head nut on it, if it starts now ure problem is because the wiring to your starter motor from the key is not thick enough.
getting a mate to hit ure starter solenoid while ure starting it, and it starting will also diagnose poor thickness wiring.
i think its this because u are obviously drawing current due to the light dimming, this is because of the solenoid
ziggy,
jaffro
yes starter to battery with the battery terminal on 1 end and a eye hook on the other and 37 inches long
Ziggy
I've not heard of anyone having any problems with the m20 lead? I know people have used E32 engines, so I assume they must have used the m20 lead anyway!ric325i wrote:i like the idea of a m20 one! but it still maybe too short?
ziggy,
Who knows when it'll be running... I'm not around at the weekend, & have no way of knowing whether it'll start when I connect it up anyway! Could take 5 minutes...
Hmmm... I've got a boot location kit for my battery - just haven't got round to fitting it in the boot yet. I don't see why I couldn't just use it to remote the +'ve terminal over to the other side of the bay though (as a temporary measure)?! Can't think how it all goes together. Anyone?
Ziggy
Do you not need it for your conversion mate?! I'm stealing all your parts here! Let me know how much I owe you btw - so far you're at least out of pocket for 2 lots of postage, plus the parts!jaffro wrote:yes starter to battery with the battery terminal on 1 end and a eye hook on the other and 37 inches long
jaffro
ive got a spare 1 lol. pm ya address a il get it in special post today so u should have it for dinner tomorrow. dont worry bout postage just send me a pic of the mani bit u ground down haha
ric325i
im in debt to carl too!
the list of bits i have from him is longer than the list of things i need to do to get my 335i running.
the relocation kit is dead easy.
i do have pics but i cant access them at work.
the positive connector is massive in length and girth. the negative is minor and there is a thinner wire which runs along side the positive - guess thats the dancer you need???
if the battery is charged use that? dont know if its the best idea as its long and may not be think enough but have a go just to find out.
jaffro
ah nobody in debt lol i appreciate all the help and info so i try to do my bit. just want mine running haha
Ziggy
If I just use the big thick bug*er to move the positive terminal over to t'other side of the bay, everything can connect there I think?!ric325i wrote:im in debt to carl too!![]()
That'll only be a temporary thing obviously, but it wouldn't half be nice to at least get it to turn over!
PM on the way, Sir Jaffro of Heroesville.
jaffro
no problem mate ill post this morn
ric325i
he is giving Gall a m30 starter too!Ziggy wrote: Sir Jaffro of Heroesville.
Carl we will crack on your m30 soon as! im actually looking forward to putting yours together as you have everything there its just a case of scratching our heads a few times and putting it together.
are you getting the diff today?
sorry off topic but its cheaper than a txt.
Ziggy
Wish I was just slightly more local so I could help! There seem to be pockets of m30 rightness - Toby & Andy up Nottingham way, Martin & Theo over in the South East, you guys oop Norf... I need to get mine finished so I can convert a few more people down here to the cause!ric325i wrote:he is giving Gall a m30 starter too!Ziggy wrote: Sir Jaffro of Heroesville.![]()
& can we start a Jaffro fanclub, or is that going a bit far?!
jaffro
aw im blushing haha. ziggy its posted and will be with you 2moz mate
ric325i
Camaraderie i think would be the right term.
fix cars drink beer, its the good life.
let us know if you get the car running tonight? the first time is the best time!
Ziggy
Well it turns over! Didn't get as far as starting before the battery ran down, but fingers crossed for tomorrow (it's raining now!)
Ziggy
Finished bolting the exhaust on too - having got the missing downpipe-stud spring from Chris W.
While I was under there I snapped this with my phone of what I removed from the mani flange - you get the idea.
Would never have worked with the E32 one...
DRIFTBOY
Almost there now!
I ground back my manifold like that too, it helped a bit but if I were you I'd be a little cautios of sharp left hand turns until you know if it's ok or not.
Good luck!
Good luck!
jaffro
have u received that battery lead yet
ric325i
Ziggy wrote:Well it turns over! Didn't get as far as starting before the battery ran down, but fingers crossed for tomorrow (it's raining now!)
well something is working now!
do you have the fuel lines the right way around? i didnt lable mine and cranked it over for ages. then i switched them and
soon my good man soon it will fire up!
i know that feeling! i have some better mounts (thanks carl) so i hope to clear that problem, esspecially as i have cut some parts down and also moved the rack along the splines as much as i can.DRIFTBOY wrote: I ground back my manifold like that too, it helped a bit but if I were you I'd be a little cautios of sharp left hand turns until you know if it's ok or not.
Good luck!
Ziggy
I certainly will be! But thankfully with this mani, if it does touch, it'll be on the main shaft of the steering coupling. That means it's less likely to lock up than if it was the shoulder that caught!DRIFTBOY wrote:Almost there now!![]()
Good luck!
Ziggy
I'll let you know when I get home!jaffro wrote:have u received that battery lead yet
Ziggy
Fairly sure the lines are the right way round - I've got the filter under the bonnet so it's pretty obvious which way they should go. TBH it's probably just a case of giving it a bit more time, or equally my (pre-facelift therefore dodgy) fuel pump could have given up! Shouldn't be too hard to diagnose... but I've got the exhaust connected now - LAME!ric325i wrote:![]()
so close then........
do you have the fuel lines the right way around? i didnt lable mine and cranked it over for ages. then i switched them andthe houses everywhere started vibrating and my ears exploded!!!
ric325i
oh gutted.Ziggy wrote:but I've got the exhaust connected now - LAME!
well atleast you can start it up and see if it all runs right and how the exhaust note sounds.
i might buy a new exhaust this week thinking about it.
anyone got a back box with a 3inch inlet for sale???
jaffro
have that stainless backbox of mine a get it converted to fit ya giant tubing haha. it does sound good though
ric325i
i will let you know on that...maybe possible. you have a pm
and the hammer bits is the most fun
ziggy for your qusetion in another thread,
position 3 is the furthest back (best for weight distribution) and position 1 would be furthest forward to front of the car.
so if you have position 3 get your hammer out and go nuts on the tunnel cause the engine will need to be set much further back.
Ziggy
It's in P3 then, & there was no hammering needed...
Only 2 options on .de mounts though, so who knows for sure where it is! Prop needed to be shorter than most have suggested though, so it's certainly not sitting very far forward...
johnl320
Chuffed you got it turning over ziggy. run the pump by bridging the relay for a minute and it should fire up straight away.
Good Luck
john
Good Luck
john
Ziggy
That's what I was planning to do... but where the smeg is it?!johnl320 wrote:Chuffed you got it turning over ziggy. run the pump by bridging the relay for a minute and it should fire up straight away.
Good Luck![]()
john
