100,000 miles :D whats on your clock?
touringsport
Mon Jan 21, 2008 10:09 pm
ideal, i'll have a play tomorrow. if it stops raining.......
if it is that, i'll have to put back the 7000 pieces of trim i've had out the inside :?
ALL WORK AND NO PLAY MAKES JACK A DULL BOY ALL WORK AND NO PLAY MAKES JACK A DULL BOY ALL WORK AND NO PLAY MAKES JACK A DULL BOY
Dipesh
Mon Jan 21, 2008 10:10 pm
My Cabs just ticked over 110k
320i Convertible
e30bmlover
Ac Schnitzer prophet
Mon Jan 21, 2008 10:32 pm
my shell has covered 115,000 miles...... she loves it :D
delae30
Mon Jan 21, 2008 11:14 pm
236,660 holy miles.
Mon Jan 21, 2008 11:33 pm
I'm guessing they still drive like new? :D
StuMc316is
Tue Jan 22, 2008 12:51 am
My 318is has 330,000 miles on the chassis. It has a 3.0L M50 with about 80k miles now. Had the M42 until about 250,000 until it was removed to drop in the 6.
Most parts have been replaced at one point or another, but the trailing arm bushings still have 330,000 miles....time to swap them out!
There are other cars in the states with 400,000+ miles, mostly E28's and M20 E30's.
Careanla
Tue Jan 22, 2008 10:42 am
Some shockingly high mileage cars out there...!!
Just hope my M20 lasts this long :)
Keeping it standard.... someone has too.
Craig Davies Photography
e30mtech
Tue Jan 22, 2008 10:46 am
i,m at 165,000 on my 1.6 m40 and it definatly starting to show with the engine
HairyScreech
Tue Jan 22, 2008 12:35 pm
the "tight" feeling is lost in things people dont consider replacing. things like reseting the preload on the steering rack pinion, the uj of the rack, the front top mounts, sub frame and trailing arm bushes, ball joints ont he wish bones, adjusting the door hinges and lock strikers, replacing the pedal bushes and the old worn throttle cable etc.
Tue Jan 22, 2008 12:51 pm
StuMc316is wrote:My 318is has 330,000 miles on the chassis. It has a 3.0L M50 with about 80k miles now. Had the M42 until about 250,000 until it was removed to drop in the 6.
bloody hell 330,000 on the chassis you must do a few miles winkeye
liam012
Tue Jan 22, 2008 2:54 pm
196,000 on the clocks original engine..... 318is
Phil325is
Tue Jan 22, 2008 2:58 pm
1989 G 325is 142,000 (drive nearly everyday) done 12,000 since April 06
josh-hocking
Teenager with Taste !
Tue Jan 22, 2008 3:10 pm
mine has 111000 miles and all original engine. its done 1000 in 2years!!! :D
rThor234
Wed Jan 23, 2008 2:09 am
My '86 325e and '87 325es both had over 200k when their odometers broke.
My 325is has 187k.
StuMc316is
Wed Jan 23, 2008 5:23 am
HairyScreech wrote:the "tight" feeling is lost in things people dont consider replacing. things like reseting the preload on the steering rack pinion, the uj of the rack, the front top mounts, sub frame and trailing arm bushes, ball joints ont he wish bones, adjusting the door hinges and lock strikers, replacing the pedal bushes and the old worn throttle cable etc.
On the steering pinion we just replace the rubber donut with aluminum. Along with stiff control-arm bushings there is no slop in the steering.
bottlecapE30
Wed Jan 23, 2008 5:32 am
Well boys let me give you somthing to look forward to
this was on the shell it had a m30 swaped in with over 300,000 miles and no rebuild.
Sadly this milage will never go any higher as it was rear ended a few years back :cry:
I had taken it cross the US a few times and up and dowm the main cost line just for fun :P
my other e30 (in sig) has 138,000 miles.
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
gooner1
Out humping Reindeer
Wed Jan 23, 2008 7:21 am
97332 on my 86 325i cab, just about run in. :D
pnd
Wed Jan 23, 2008 10:18 am
MINES done 90k(2.5) genuine and still feels tight as people have said it is very different from the feel of most e30's by now hence why good cars should command a significant premium price wise. however mileage is not the only reason these cars tend to feel knackered a lot's down to abuse and lack of maintenance and remember a good percentage of e30's aren't showing their true mileage anyway.
Barnz
Guildford Geezer
Wed Jan 23, 2008 10:30 am
My 325 is on 164600 and still going strong, well apart from needing new injector seals which went pfhutt last week. Rest of car is stonking though, considering it was £230!
E34 525tds - on the way to replace 325i
E30 / 34 spares
BMracing
Wed Jan 23, 2008 8:15 pm
bottlecapE30 wrote:Well boys let me give you somthing to look forward to
Wow, so this car had done 300k on the original engine, and has now done 200k on the m30? Plus what mileage was already on the m30!?
Max
bodger
mines got 104 000 had it for 8 months and still not driven it yet :cry:
Daddycoolest
Fri Jan 25, 2008 7:19 pm
My E30 got to 129,000 in november, then the head went and cracked grrrrr, She's nearly back on the road now though, when i get time to finish her off & after spendin all this dosh on her she had better get to at least 240,000 before she needs anything else lol.
Rear wheel drivers do it with their arse hangin out!
Frenchy
Fri Jan 25, 2008 9:25 pm
Good point there from Hairy Screech about the bits we miss and often simple, mine has done 99K original and has been well maintained by a good specialist.
Wish me birds punani was as tight ! winkeye
Alpina B3 3.3 Santorini Blue,White Buffalo hide with Blue Piping,Black Shadowline. No 242.
318 iS Diamond Schwarz.
Porsche 944 Turbo S,Special Order Black,Very Limited Numbers and Very Quick......;-)
