Could this be because I have plugged the two pipes that go to the TB, they weren't longe enough to connect one to the thermostat housing and I didn't have a sutible piece of pipe to connect them. Would that make an air lock form? I really don't want to cook my engine as I have to drive to Leeds tomorrow?
Thanks for the Help
Right just been out having a fiddle and although the engine is hot the temp gauge is cold and the rad is cold. So I must have a huge air lock. And then the fcuking bleed screw has sheared
