anybody going to brands on june 22nd
all booked and nearly done next stage of bits to my car
lowered the back by 60mm (finally)
to do -
fit braided brake hoses
dot 5.1 brake fluid (any tips on flushing)
take out fog lights and fit a bit of air duct to brakes
some wiring bits to move and seat bits in back
can't wait
Brands Hatch june 22nd
Borderbmw
Sounds good mate,with regards to the brakefluid change ive always found the easy bleed bery good,just fill it it and after a little while of bleeding the new stuff will flush the old stuff out,just make sure the level doesnt drop too far or its air bubble city!
Good luck though mate.
Of all the people ive met,youre definitely one of them!
chief
thanks for the tip m8
i got the easy bleed kit and i think its a good tool
just worried about mixing the 2 fluids
one is hypoglycomwhatever the other is a non water do it
there you go theres an idea of my technical knowledge in 2 sentences
Borderbmw
Guessing you mean hygroscopic,ie absorbs water and the 5.1 is a silicon based fluid if i remember? as long as you use say 1.5-2 ltrs you should be fine braking systems actually dont contain that much fluid mate,and they dont mix really as ones mineral based and the other isnt so you shouldnt really have any problems
chief
sounds like you know your stuff
thanks for the tips
my target is to beat 60 seconds per lap
thanks for the tips
Borderbmw
I have a few cells left still,wish i was coming with you mate,until last august i lived about 25 mins from brands hatch
chief
would i be correct in saying knockhill is your closest
Borderbmw
yep knockhill or crail
chief
crail
thats a new one to me
is it an airfield or ??
Borderbmw
yep its an airlield in fife,nearer to edinburgh than knockhill and further over towards the coast
tylerma
so what is happening at brands then
is it a track day
is it a track day
chief
trackday
booked by easytrack.co.uk
lots of othe BMW on there so maybe someother zoners included
