im new to bmw scene ive recently bought e30 320 2dr with the head gasket blown and ive got around £1000- £2000 to spend on the engine conversion.which engine conversion would u recomand? 325,327,328??etc
majority of the work will be done by n my brother whos a mechanic
thanks
which engine conversion????
fuzzy
the m30 3.5 from the 535? a complet donor car for a few hundred quid and 218bhp as standard.
Phatz
2.8.... But thats only because I'm doing it at the moment.
I would say it depends on what your after in terms of performance and also how much work you want to put in.
I chose the 2.8 because it keeps the engine bay standard looking and other things such as suspension/transmission etc..don't have to be altered, hence less overall work.
My advise would be to do your research before making a decision.
The Sport - Gone to a new home to be slowly brought back to life
jaffro
than theres the prop to sort a engine mounts but well worth it in the long runfuzzy wrote:the m30 3.5 from the 535? a complet donor car for a few hundred quid and 218bhp as standard.
scotty86d
2.8 is quite good from what people say. but then really you'll want to run after markert managment like megasquirt to get the most of it, and get rid of the bosch unit.
i went in a friends 3.5 powered e30. it was stripped and cammed but foook me was it cool, quick and sounded like a mentalist. highly recommend that.
Charlez
My self and Scotty86d are looking at the 2.8 or the 3.5 for my car at the mo and tbh the 3.5 seems to be the nice option.
sag
thanks guys for ur opions............ im looking at the 3.5 conversion and might go 4 it. is it a straight foward conversion meaning IN n OUT job, bar a few problems . n what things will i be needing from the donar and my car and any modificatian parts
billy_whizz
isn't the 3.5 much heavier and affects weight distribution and so handling?
fuzzy
a custom made prop costs another £100. engine mounts for this conversion can be bought of the shelf iirc .jaffro wrote:than theres the prop to sort a engine mounts but well worth it in the long runfuzzy wrote:the m30 3.5 from the 535? a complet donor car for a few hundred quid and 218bhp as standard.
M30 3.5
d1mmy
- Boost Junkie
what about a M50 2.5 out of e34 525i.
Modern (ish) 24v Straight Six. Good alrounder
For sale 325i Sport Turbo & 318i (Sport) M50B25
jaffro
yep it all mounts up in the end as im in the middle of the swapfuzzy wrote:a custom made prop costs another £100. engine mounts for this conversion can be bought of the shelf iirc .jaffro wrote:than theres the prop to sort a engine mounts but well worth it in the long runfuzzy wrote:the m30 3.5 from the 535? a complet donor car for a few hundred quid and 218bhp as standard.
