I have just purchased a Cosworth powered E30!
dannyg1983
Mon Jan 07, 2008 10:36 pm
I have just purchased an BMW e30 with a stage three Cosworth engine fitted —a 360bhp!
This is a truly brilliant car —a very nippy to say the least.
Questions:
1. Can I fit an electronic boost controller? I always had one fitted in my skyline and it was nice because if a friend/ girlfriend were driving the car I could set the boost to a more sensible value. This would not cause problems with the mapping?
2. Does the header tank need to have a cap which releases pressure as a specific value? Many of the ones on e-bay seem not to have pressure release valves.
3. I have no rev gauge, one wan never fitted. What kit do I need to buy to make this work? —a It has a Cosworth gearbox fitted.
Parts needed:
1. Rear seats for a 3 door
2. Front and rear seat belts —a complete with all fittings and fixings
3. Glove box assembly
4. Mechanism for securing spare wheel.
5. Boot carpet.
Cheers Dan 07979 50 70 80
munky30
100% Pure Council
Mon Jan 07, 2008 10:39 pm
weirdo.
jbh
Hartge Crew
Mon Jan 07, 2008 10:44 pm
hi dan can do parts 2, 3 and 5 if your needing them where are you located ? also for the cozzy engine answers speak to fuzzy hes done this conversion on a touring
Cossie_Can
Very Nice Buy!
I had a 360 bhp saff Cossy up till April last year,
Ran constant 12s at the Pod best being 12.63secs
I converted it from 4x4 to 2wd for more sideways fun :wink:
So I can only guess how quick that is in a light E30 :D
ANYWAY I have seat belts with everything and boot carpet for sale!
Belts £25 and Carpet £5!! :D
blitz877
AKA ajm-e30
Mon Jan 07, 2008 10:46 pm
:ttiwwp:
jbh
Hartge Crew
also forgot to say welcome and when are you getting some pics up ?
PMJ
Mon Jan 07, 2008 10:49 pm
I saw this advertised on PH and thought what a proper toy that would be....
Mon Jan 07, 2008 10:51 pm
Oh no! Not more Ford numpty's :)
Fal_325i
Mon Jan 07, 2008 10:52 pm
cecotto_singh
Mon Jan 07, 2008 10:59 pm
welcome to the e30 cozzie club!
dannyg1983
Mon Jan 07, 2008 11:02 pm
Cheers Guys, the 1/4 time was 12.9 seconds with 18' rims - the problem is getting the power down. Will get some pics up soon.
Mon Jan 07, 2008 11:06 pm
As much as the latest Mitsuboshi Evo I was reading about the other day 8)
http://www.mitsubishi-cars.co.uk/evolut ... trCar1=QF7
78dude
Mon Jan 07, 2008 11:09 pm
I think my next car will be an E30 with a Volvo 940 TIC Twin Cam engine, I live in Sweden for £$┚¬Ã¢”š¬{{{{{!!!!!
winkeye
dannyg1983
Mon Jan 07, 2008 11:32 pm
I am also after a genuine sport kit, and the inner nearside head light
cheers Dan
jbh
Hartge Crew
Mon Jan 07, 2008 11:41 pm
got the head light aswell bud keep your eyes on the forsale threads for the kit they do come up but there never cheap
bmw-mad
Tue Jan 08, 2008 12:01 am
welcome to the zone mate i saw this car the other day and thought it was great.
SPADGE
Tue Jan 08, 2008 1:06 am
dannyg1983 wrote:I have just purchased an BMW e30 with a stage three Cosworth engine fitted —a 360bhp!
Questions:
Parts needed:
5. Boot carpet.
Well done!
I only saw the car on pistonheads this evening and was going to call the guy tomorrow but i guess there is no point now :cry:
I wouldn't bother with an electronic boost controller on the yb personaly but a quick, easy and cheap way of regulating the boost would be to put a switch into the amal valve wiring to give you a high/low boost setting.
This is assuming it is running the amal valve?
The trigger wire for the rev counter on the cossie engine loom is green and should be easy enough to splice into the wiring for the original e30 tacho.
You will definatly need the correct pressure cap for the header tank.
Which h/t is it using? Is it a bayonet fitting cap or threaded??
I have most if not all of the bits you require as well and if you need any advice re the YB give me a shout.
Spadge...
Chris-W
Tue Jan 08, 2008 8:52 am
dannyg1983 wrote:
Parts needed:
5. Boot carpet.
I have all those bits - let me know if yo're still looking.
Cheers,
Chris
R4N_S_S
Tue Jan 08, 2008 2:11 pm
cossie power all the way :D
**BANNED**
Tue Jan 08, 2008 2:18 pm
I have a grey rear bench seat from my 4 door...does yours have 2 doors one side and one on the other?
Youth is wasted on the young.
Tue Jan 08, 2008 2:27 pm
cool i bet its quick, nice buy there
:D :D
BreadBin
Tue Jan 08, 2008 3:03 pm
How well do the 325i brakes cope?
Humph
fuzzy
He who sleeps with "Gingers"
Tue Jan 08, 2008 5:49 pm
nice one, welcome to the e30cosworth zone 8)
get some pics up asap. mine runs using the standard e30 rev counter and im using the same borg warner t5 rwd box.mine was converted to run on the bmw hydraulic clutch system after many snapped cables.
fuzzy
Tue Jan 08, 2008 5:52 pm
having read the for sale add yours is a very similar spec up to mine although ive not changed my injectors and chip yet to go to stage 3 :cool:
maxfield
Tue Jan 08, 2008 5:54 pm
Wrong. In so many ways!
fuzzy
Tue Jan 08, 2008 5:59 pm
why does it have the restrictor on the turbo inlet? my old turbo used to be a .63 housing with a 34mm restrictor but boost wasnt coming in until over 2500rpm. i changed to a stage 2 t34 with .48 housing after turbo specialists recommendations and the boost now comes in at 1400rpm. much more useable .
fuzzy
Tue Jan 08, 2008 6:01 pm
maxfield wrote:Wrong. In so many ways!
wrong but also oh so very right :D
dannyg1983
Tue Jan 08, 2008 6:11 pm
Apparently the turbo is out of a race car and the restrictor has been skimmed out. Do you know where I need to connect the green wire on the back of the rev counter? The dials are out of a 4 pot so should be ok.
What 1/4 times have you run fuzzy? Can't wait to go heads up with my mates 410hp skyline! :D
maxfield
Tue Jan 08, 2008 6:17 pm
fuzzy- it's wrong, get over it :wink:
He won't of done quarter miles in that, it would break half way down :o
