are all parts inter changable on the 2 engines like inlet manifold, gearbox, clutch etc
as may be buying a 1.8 auto engine and was wonering if my 1.6 flywheel, box and clutch will fit straight on and also the inlet manifold etc
thanks
m40 1.8 and 1.6
e30mtech
blitz877
- AKA ajm-e30
the 2 m40 engines are the same except the inlet and exhaust manifold i beleive mate
ed325i
The parts are the same.
They use the same head.
e30mtech
what about afm and ecu, i'm guessin the ecu will def be different but what bout the afm, also is the loom etc all remain the same.
as i will be hopefully getting the 1.8 engine but will need to put most of the parts off my 1.6 engine onto it,
is the cooling system all the same as well
cheers
cheers
E30Mark
Spend some time getting to grips with http://www.realoem.com/bmw/select.do and you'll be able to check individual parts usage on other models etc.
PM for details
PM for details
