bumper mounts
stevo
just a quicky, are the torx bolts that hold the bumpers on prone to snapping, or are they generaly ok? i'll be removing them soon to fit fibreglass valances ive got and they look a bit rusty
alpinachris2
hi mate ,i took my rear bumper of 2 weeks ago bolts were really tight , took a big extension bar to shift them, but didnt snap,! you need arms like garth to shift them if they aint never been removed before. kept thinking the torx was gonna slip !!
Widge
Came clean undone on my breaker. They looked quite rusty too, but I suppose it depends how lucky you are.
A1BMW325iSport
i`ve had some totally seized up on the 325i i broke it had m-tech kit on so i was determined to get off the bumper, out came the grinder here is some pics.....
bmwe30mtech
If you just cover them in loads of wd 40 and let it 'soak in' they come off twice as easily.
stevo
hmm, looking at those pics im getting scared
think i'll start lubing them up tonight! cheers for the feedback guys, hopefully i'll get lucky
dazleeds
- old skool raver
if it all goes a bit pete
let me know i got a pair here just wd for a couple days then go for it mate Daz
www.oldskoolfantasy.co.uk
The U shaped piece of metal holding the square nut in place has been known to break away where its welded to the vertical tube. Should still come apart, but needs to be welded back on to reassemble.
Use plenty of coppergrease when refitting. Also clean out the thread of the front towing eye, and stuff that full of coppergrease as well. It may pay dividends one dark rainy night.
