more questions but this time with piccies
AndyBird
Post Thu Jun 02, 2005 7:47 pm
318i F reg M40 engine
right have cleaned AFM, TPS, ICV, you name it :D still bloody mising on idle (sounds like a V8)
http://img.photobucket.com/albums/v209/ ... tions1.bmp
can anyone help
AndyBird
Post Thu Jun 02, 2005 7:49 pm
need to know what the vacuum hose is in the second piccy and what the screww on the MAF does :)
Ant
Retired Team Member
Retired Team Member
Post Thu Jun 02, 2005 8:05 pm
the screw set the idle mixture strength dude, alter it only with the use of a gas analyser or you could end up running worse !
the vacuum hose you mention.. should be the one that runs to the servo ? the pics are a tad small to see clearly what you are asking though
M40 massive... help a fellow zoner out :wink:
AndyBird
Post Thu Jun 02, 2005 8:12 pm
just what does the vacuum hose do and that bit about the mixture :)
AndyBird
Post Fri Jun 03, 2005 7:53 am
the vacuum to the servo is further over this vacuum comes off the throttle plate the opposite side to the fpr run.
the mixture screw, does it get richer when turned clockwise or anticlockwise? i take it that this sets the mixture throughout the range, is it possible to cause the car to run lean / richj as my m8 said he could smell petrol when i was booting it he was following me.
the only reason i say is that i have a sneeky suspishion (speeeling) this has been played with
gonna change the plugs tonight except for that im stumped
AndyBird
Post Sat Jun 04, 2005 9:02 pm
anyone know which way the screw goes to make the car run leaner?
ive changed everything!!!!!!!1
plugs
lead
rotor
Cleaned ICV, AFM, TPS
checked for vacuum leaks and found none
still dont know where that vacuum pipe or the plug goes
still bloody misses on idle :x
gonna burn it :x
Simon
Post Sat Jun 04, 2005 9:16 pm
Hi mate sorry you're not getting any replies...
The mixture screw should have an anti-tamper plug fitted, so if this is missing then it's probably down to someone messing.
Are there any local quick tune places that could look at it for you??
Lumpy idle deffo sounds like a vacuum leak though, if I remember correctly, there's a small blank pipe under the throttle body on the M40, and the plastic plug on the end of this pipe tends to crack and create a vacuum leak...
