door seal?
deane30
Thu Dec 27, 2007 4:22 am
Hi Everyone
I have water leaking into the left rear footwell of my e30 (4 door) when it rains.
There is a photo attached and you can see there is a small trail of water leading from the bottom of the plastic piece that the front seat belts come out of, into a small puddle.
I think it may be coming through the rubber door seal. Has anyone else had this problem?
I did get someone to pour water on the door while I was inside the car to see if i could spot where it was cominf through and I peeled back the door card a little but i could not tell for sure.
Thanks,
Dean
deane30
Thu Jan 03, 2008 8:14 am
bump
beardymat
Thu Jan 03, 2008 8:18 am
could well be the door seal but it might be worth checking the plastic membrane under the door card is present, i have seen it where this has been removed or poorly replaced and water finds its way in that way. take the door card off and check.
deane30
Thu Jan 03, 2008 10:21 am
Thanks will check, whats the best way to replace this if it is missing or shotty?
