what ratios did the above come in and would it be suitable for a M30 conversion bearing in mind i already have a e30 m3 prop.
thanks.
E30 M3 LSD.
gooner1
- Out humping Reindeer
Ant
- Retired Team Member
3.15:1 and 3.25:1, you can also find these ratios in chrome bumpered 323's with the dogleg gearbox dude.
I have both here, plus a 2.89 from an E34 in the E30 casing.
HTH
edit: Demlotcrew had one for sale pre christmas, was brand new iirc..... worth a gander ??
HTH
Email FTW
gooner1
Thanks Ant. its just that i spotted an e3 m3 lsd on Pistonheads and wondered if the ratio was better suited to the M30 conversion. Already have an e30 3.64 lsd which seems to be a better option anyway.
The one on p/heads is going for £175 if anyones interested.
mcnrss
has any of you good gentlemen got an 3.25 ratio or less for an e30
will a large case m535 3.07 diff fit?
thanx
thanx
FormerMember
Large case E28 diff won't fit, it's about twice the size on typ188-diff which is the big e30 diff.
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
