removing top center vent to fit screen. help wanted??
beemer_jay
Fri Dec 28, 2007 7:07 pm
hi guys has anybody done this as i want to but not to sure how to go about it??
i have a pull/ motorised screen that i wish to fit here, and it has a seperate din sized dvd player which i will fit in standard slot. so all help would be great???
cheers jamie
franco90
Sat Dec 29, 2007 7:23 am
try this website
www.mp3car.com
dips346
London Meets Main Man
Sat Dec 29, 2007 7:41 am
you will be better off fitting the head unit lower down in the center console just behind the ash tray and put the dvd where the head unit would have been as the vent size is much bigger then din size but you can make a face for it .
you will also have to block the venting behind to stop heat getting in that area
smithy318i
Sat Dec 29, 2007 10:57 am
The center vent is held into the dash by 4 plastic flanges.
2 large ones on top and 2 smaller ones on the bottom.
The best way to remove them without damaging the dash would be to remove the dashboard and push it out from the back.
If you cant do that (or are unwilling) the plastic clips are 5.5cm from the center on the top and bottom. You might be able to insert a screwdriver into the radio hole and lever it out from the bottom.
beemer_jay
Sat Dec 29, 2007 2:01 pm
cheers for the help guys. :)
beemer_jay
Sun Dec 30, 2007 7:22 pm
dips346 wrote:you will be better off fitting the head unit lower down in the center console just behind the ash tray and put the dvd where the head unit would have been as the vent size is much bigger then din size but you can make a face for it .
fitting behind the ash tray area seems a good idea. is it simple to cut out a din slot in the plastic or are there things behind to watch out for?? as i would like to cut it out in place??
jamie
dips346
Sun Dec 30, 2007 8:43 pm
jamie
very simple you only need a knife ,loads of room :D
beemer_jay
Sun Dec 30, 2007 8:58 pm
cool cheers dips
gra325i
Mon Dec 31, 2007 12:10 am
behind the ashtray is the best place for it mate..but i like smithy,s idea of putting the head unit up there in the vent.. i can see that being the springtime project for the sport..if i ever get the paint job finished :roll:
Dips.. like the new sigpic.. leaves the door open for my white/blue combi winkeye
beardymat
Mon Dec 31, 2007 12:19 am
i fitted a stereo down there in my 320 i had several years ago as it was one of the first kenwood masks without the removeable faceplate. fitted it in the centre console and made a vinyl covered plate to disguise it from the scrotes who tried to remove it from my previous car.seem to remember making a frame to space it forward a little too for some reason.
just a point but if you have aircon dont break out the stanly knife cause you will have a bigger heater box and i dont think the radio will fit.
dips346
Mon Dec 31, 2007 12:26 am
you still doing it :D
gra325i
Mon Dec 31, 2007 12:47 am
yeah dips..in the process of prepping the kit just now..far too cold for painting at the minute tho..its -4 up here tonight :roll:
BadDave
Wed Jan 02, 2008 9:01 pm
There is an easier way to make one fit folks
Use the trim panel from a LHD car to allow the screen to power out without hitting the indicater stalk
dips346
Wed Jan 02, 2008 9:15 pm
BadDave wrote:There is an easier way to make one fit folks
he has din units to fit not just the one
BadDave
Wed Jan 02, 2008 9:17 pm
:oops:
Should have read it more thoroughly
My apologies
