can anyone help???
325i turbo??
- moody_bitch
ok here goes..... as you av prob read in other posts my fella wants another e30, only trouble is i need some info on having a 325i turbo'd using a turbo diesel bottom end........
can anyone help???
													can anyone help???
						- moody_bitch
need to know what turbo to use and wat td bottom end i should be using??
someone please help!!
				Ant
 - Retired Team Member
 - Contact:
Stock bottom end will suffice,  uprate the headgasket and headbolts and thats good enough for 10-12 psi
For turbo, use the biggest you can afford, T3 is too small but makes a very torquey car, T34/35 is pretty decent for sub 300 HP and great midrange, if you want the big bang delivery then its gotta be a Holset or GT37 in big trim.
or supercharge it....
HTH
HTH
 Email FTW
- moody_bitch
wouldnt a turbo diesel bottom end make much diff then??
and wat bout the oil return???
- moody_bitch
So.......
can anyone help me???
- fowler
 - Boost Junkie
 - Contact:
As previuosly stated the standard bottom end will take 10-12psi all day long !!
a diesel crank will increase stroke and 2.7 lower comp can be achieved for turbocharging/ supercharging.
When Tuboing a 325i your main factor will be cost.
it all depnds what you have to begin with.
Your best bet is to speak to Ant he is the guru on F/I on e30's
BUT remeber "WHATS YOUR BUDGET"
as he has some very good superchager kits available.
if you do need to ring him the number is 01959534718.
I know this subject very well
i own a 2.7 low comp turbo running Vems management, Holset Hx35w running 1.6 bar and its fast but no cheap
could be for sale if the right offer comes along.
Regards
Ben
Regards
Ben
EX A-Tech Workshop bitch !!!
gone but not forgotten
