Audi quattro dials
Karan
hello
i just bought some audi dials and am gonna fit em in my sport...
i think buster has done this, how do i go about linking em up to my m20 engine....they come with senders.
also shall i put em above the ashtray or make a pod to go in the centre airvent?
cheers
Karan
cheers
Karan
Sjoerd320i
I'd put them in the center air vent look cooler IMHO
Karan
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %3AIT&rd=1
heres the ebay link....
oil temp/press and battery voltage....
i was thinking-----oil temp in sump, oil press in pressre switch on right hand side of block and voltage should be easy......
thing is what thread etc will the senders be?
Karan
Karan
Davenotouring
Swirly has made a wicked pod to sit in the centre vents!!
BMW 328i Cab - Daily Slag
Karan
so i have seendavetouring wrote:Swirly has made a wicked pod to sit in the centre vents!!
reckon he could knock one p for me....LOL
Davenotouring
Worth an ask!!
325iSportMark
There's an article from Jordan on R3V forum on making a pod fro the air vent slot, looks cool
Karan
cheers!325iSportMark wrote:There's an article from Jordan on R3V forum on making a pod fro the air vent slot, looks cool
jst had a look....looks like a lot of effort./LOL
SwirlyE30
lol it is a lot of effort mate. Taken me a long time to mold it all up, then realise the holes were too small so i redid it all lol
. Not sure about my quality in terms of doing it for other people lol, might not be all that good!
Ashtray ones are pretty cool, lot easier to do as well i imagen.
1986 Chevrolet Corvette. 330ftlb torque....V8s rule!
Karan
i may just cut the centre console and put them in that just in front of the ashtray if u see what i mean....
like wher ethey are on the audi
A1BMW325iSport
i reckon the ashray area would look good, but the problem is you don`t want to have to keep looking down whilst your driving.
320Touring
he's already too busy staring outta the side windowsA1BMW325iSport wrote:i reckon the ashray area would look good, but the problem is you don`t want to have to keep looking down whilst your driving.
Karan
i tend to shut my eyes and pray approach....works a treat320Touring wrote:he's already too busy staring outta the side windowsA1BMW325iSport wrote:i reckon the ashray area would look good, but the problem is you don`t want to have to keep looking down whilst your driving.
buster
i will take some pics tomorrow of the sender unit etc.
Karan
cheers!buster wrote:i will take some pics tomorrow of the sender unit etc.
buster
Heres what i was using on my m20.
The round sender is the audi one.(Ԛ£60 from stealer).I got it from the car i got the dials out of.One of the electrical connectors is an oil light and replaces the BMW original pressure switch.The other electrical connector on the sender is oil pressure sender.
I have the audi sender screwed into a t piece which i got from demon tweeks.On the end is the temp sender which is a BMW one from the E30 M3.I had to make a brass adaptor though which you can see between the temp sender and the tee piece to allow the oil to go around the probe end.
That whole lot replaces the original pressure switch location near the oil filter.
The large threads are all M12x1.5.
Heres another pic with the audi sender unscrewed,which you need to do to fit it all.Screw the top part in then screw the audi sender in after.
The audi sender is looking past its best but it works fine,i made a bit of a mess of the sender by trying to remove it with stilsons instead of doing it properly by the hex part,lucky i didnt damage it !.
Heres a pic where ive fitted them.I kept the original audi backing plate because i think they look better in that because without it they look boggle eyed
poking through the center console.
I then fitted the chrome rings which are the same as the ones i have on the heater controls.
Heres one of my m3 dials just for the hell of it !!
Widge
Hi guys I'm doing this too, just need to get senders and Ԛ£60 sounds like a lot of mullah
I put mine in the centre console, but I dumped the plastic surround cos I thought it would look out of place.
Apologies for the sh1t photos, taken on my phone
If you want info on wireing them up look here
http://www.thepaty.plus.com/8v/howto/VDO.htm
cos it's a common mod on the Golfs
Demlotcrew
Busters and Widge, those dials are way too low, i once also had something like that, but i just didnt look at them cause they were too low and to hard to read.
So Karan stick em up on the Vent, or get one of those A pillar ones.
Andrew
Andrew
Widge
Well each to his own. Thats basically where they were in the Audi coupe they came out of. I can see them perfectly clearly, and it's not like I'm going to be looking at them constantly. Whatever you do Karan please don't get one of those A pillar pod thingys. They're soooooooo naff / chav.
buster
they arent to low for me,i have long legs so seat is right back,they are easily read when driving,actually in the audi they are more difficult to read as they are sat at a strange angle
Widge
Buster, what does the red button do?
And are you saying the audi oil pressure sender works on the bmw oil light in the dash too? or have I read that wrong?
Karan
u read that right
cheers andy u da man!
Widge
If I was you karan I'd drill them in where mine are, so many people who are in my car a lot haven't even noticed them, and said when I told them that they look lik they're supposed to be there
Unless you want to go for the racing car look, I just didn't want to loose the vents. Cheers for the pointer, I'm poping down to audi today, will keep you posted.
buster
Karan,anytime bud.
Widge,yeah thats right the other connector on the audi sender replaces the BMW oil light sender so just cut the plug off and wire it to audi sender using a spade clip
Widge
Wicked, I thought I was going to be having to use 2 t pieces, right off to audi after neighbours
buster
Where i made the brass connector you can just use the t piece,screw in the audi sender then,screw the m3 temp sender into the sump and then screw the sump plug into the end of the t peice therefore the brass bit isnt needed.
Widge
I assume the audi sender won't just fit in to the whole left by the bmw pressure switch? Then with M3 sender in the sump no need for t pieces. Na that would just be too easy.
Widge
Fcuking fcuk fcuk arseholes
Part number 035919561A Oil pressure Gauge sender 0-5 bar / 1.8 bar from the Audi dealer Ԛ£68.44+vat
AAAAAAAAAAAAAAAaaaaaaaaaaaagggggggggggggghhhhhhhhhhhhhh
I'm looking for one on Ebay now. Do you think ECP will stock one, bugger should have bought a set of dials with seders like you Karan.
The M3 oil temp sender is Ԛ£18 + vat from BMW so I'll be getting one of them then.
At what oil pressure is the BMW dash oil light supposed to come on? Anyone?
buster
i told you so
.expensive isn't it.Why not try your local scrap yards.Them gauges were fitted to the coupes and i think some 100's .
or try an online audi breaker
Karan
buster says its the same for both audi and bmw so thats not a prob
Widge
I'm gonna try an online breaker now. Can't find any on Ebay, there were loads last week. If there were any in local breakers I would have got the gauges from there, don't see many coupes or quattros in srappys now.
I'll get a BM temp one and put it in the sump.
At what oil pressure is the BMW dash oil light supposed to come on? Anyone? Anyone? Anyone? Looked in the manual can't find it.
