looking at buying a cheap 4 door but there is a problem with the clutch as in.
When the clutch is pressed, it will work for about 30 seconds, then the oil pressure in it will drop, releasing the clutch slowly
any ideas is it costly or just a pain in the arse to do i'm assuming its the cylinder gone
clutch problem
I'd go with the cylinder, just a fanny on more than anything, good haggling point though, when I rang to get a quote for a new clutch at a garage they quoted me £250, and that was labour only!
1990 318i Lux
- Brianmoooore
Easily fixed, but deduct at least £150 off the price you would pay if it wasn't faulty.
