m20 turbo kit
maddogbarker
Post Fri Dec 07, 2007 2:05 am
hi, looking to turbo my 2.7 and was just wondering what the job is like? im pretty good with mechanicals and have done a lot of work to my e30, just wondering on a scale of 1/10, also will i need anything else i.e uprated ecu, chip, injectors, etc etc. oh and what do i do about the exhaust downpipe as it wont go onto the turbo!
Turbo-Brown
Boost Junkie
Post Fri Dec 07, 2007 8:19 am
Guess it depends on how handy you are with a welder really.
I'd say a straight-forward conversion would be a 3/10 with 1 being easy-peasy-poo, and 10 being nigh on impossible.
You need to junk the standard ECU to do the job properly, buying something mappable which can 'see' boost pressure.
Injectors definately need uprating, and if you're doing the job yourself, you'll need to fab up a down pipe.
maddogbarker
Post Fri Dec 07, 2007 11:08 am
would it still give a good increese in power if i used the stock ecu and injectors for now, until i suss what ecu to use to unleash the real bhp?
Gunni
Post Fri Dec 07, 2007 11:21 am
No it will not unless you use other measures to get more fuel flow.
like higher fuel pressure using a rising rite fuel pressure regulator
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
maddogbarker
Post Fri Dec 07, 2007 11:36 am
so where do i get the correct ecu and injectors?
