Click for advert
Any comments on price etc? seem OK to me,
Anything to look out for if we did go and view it?
All comments appreciated
No rust probelms on the body - just the brake pipes that you have to look out for.smithy318i wrote:dont early E46's have rust problems around the rear axle ?
also the later valvetronic engine is to be avoided on the 318i
Ant you have e mailI have 5 genuine thick and thin MV 18" if anyone fancies them BTW
This does sometimes happen, but is pretty rare, and certainly not common.bss325i wrote:A common probem on Pre 2000 coupe's that was that the diff mount bracket could crack and come away from the floor pan.
This only effects coupes, 323 upwards. I know, my cars just gone in for it!bss325i wrote:A common probem on Pre 2000 coupe's that was that the diff mount bracket could crack and come away from the floor pan.
The engine will misfire.....tomski wrote:How do you know when the coil packs fail mate, my 330 Petrol has just started giving me trouble when starting. It has started everytime so far but its taking more and more turns before it will start.
Cheers Andrew
