How about those Z3 rear shock mounts?
Looking for genuine BMW parts at discounted prices? Try here!
frankiej
Post Wed Nov 21, 2007 7:00 am
Paul, what's the difference between the standard issue rear shock mounts and the "Z3 reinforced rear shock mounts" that I've read about? Also, what's the price on each?
Thanks a lot,
Aaron
No A/C, no PWR steering, no ABS... It's a race car! '89 320i Touring / DiamondSchwartz Metalic
zimmerbimmer1
BMW Parts Meister
Post Thu Nov 22, 2007 12:03 pm
It is not a reinforced shock mount but a reinforcement plate that fits the other side of the body to reduce body flex
for the ultimate I would go for E46 M3 Cab Rear shock mtgs (more hard wearinbg than standard) which are £15.72 each
with the reinforcement plate £9.19 each
frankiej
Post Mon Nov 26, 2007 2:06 pm
Is the plate part # 51718413359?
zimmerbimmer1
BMW Parts Meister
Post Mon Nov 26, 2007 2:38 pm
frankiej wrote:Is the plate part # 51718413359?
It sure is :D :D
frankiej
Post Mon Nov 26, 2007 2:42 pm
Ok, cool. I'll be getting back to you hopefully.
Thanks a lot Paul,
Aaron
SHAZ1
Post Tue Nov 27, 2007 11:21 am
zimmerbimmer1 wrote:It is not a reinforced shock mount but a reinforcement plate that fits the other side of the body to reduce body flex
Hi just read this post sorry to jump in but also intrested in the above parts.
Can you please give me the price for 2 of the above mounts with the reinforcement plates. How can i order from you is there a website or contact details thanks
Shaz
frankiej
Post Tue Nov 27, 2007 12:52 pm
Hey Shaz, the price for them would be 49.82. I believe that you just PM him to make an order.
-Aaron
SHAZ1
Post Thu Nov 29, 2007 5:40 pm
Thanks mate will be ordering soon
zimmerbimmer1
BMW Parts Meister
Post Thu Nov 29, 2007 5:50 pm
or give me a call on 01242 257999 between 8.30-4.30
frankiej
Post Fri Nov 30, 2007 9:15 am
Haha, ther you go SHAZ ^^^
AlpineAde
Post Fri Nov 30, 2007 9:20 am
Guys, I run uprated rear shock mounts with the Z3 reinforcement plates.
Well worth it in my opinion. And if you run uprated suspension you really do need to think of the rear shock mounts.
frankiej
Post Fri Nov 30, 2007 9:26 am
AlpineAde, are you running on Eibach springs by chance?
AlpineAde
Post Fri Nov 30, 2007 9:35 am
Their pro kit, yes.
Also running Koni yellow adjustable dampers.
frankiej
Post Fri Nov 30, 2007 10:09 am
Do you have the part number for the pro kit? I'm having a hard time with finding it, I don't know why.
AlpineAde
Post Fri Nov 30, 2007 10:24 am
Interesting. I went to Eibach's page and did a search trhinking I could just grab some part numbers for you.
http://eibach.com/cgi-bin/htmlos.exe/02 ... 9300016620
They don't seem to have anything listed for a 1989 320 touring.
Was that the car you were thinking of getting springs for?
I think the part number for my 1989 325i was 2003.140.
I don't have the packaging anymore and it is not mentioned on the receipt.
AlpineAde
Post Fri Nov 30, 2007 10:28 am
Though this guy has the Pro kit on his 320 touring:
http://translate.google.com/translate?h ... 2%26sa%3DG
frankiej
Post Fri Nov 30, 2007 10:29 am
I was going to get the ones for the 325i to put on my 320i. They have the 320i listed on the German site, but I can't find those part numbers listed anywhere else.
AlpineAde
Post Fri Nov 30, 2007 10:39 am
Does the 2003.140 help?
I might be able to get the numbers off the actual springs. WOuld this help?
Let me know and I'll have a look.
frankiej
Post Fri Nov 30, 2007 10:46 am
I 'll see what I can do with 2003.140. Thanks a lot man. :)
AlpineAde
Post Fri Nov 30, 2007 10:47 am
OK. Right click on the image and select "view image". This will open the image at full size in a new window.
Part numbers are on each spring. I hope this helps.
Sorry for the OT everyone.
frankiej
Post Fri Nov 30, 2007 10:49 am
Nope, my network blocked the image... :(
AlpineAde
Post Fri Nov 30, 2007 10:53 am
I hope these numbers are correct. It's the opnly image I have of them:
2 x SW
20 02001VA
2 X SQ
EW2003102HA
If you ring up and quote all those numbers, including the 2003.140 I'm sure they could tell you yes or no on a 1989 325i.
If you get a puzzled response I'm probably missing some numbers that haven't shown up in the photograph I took.
You local Eibach distributor will know for sure, however.
frankiej
Post Fri Nov 30, 2007 1:25 pm
Thanks Alpine, I found them. $259 is what I'm looking at. I think that I found these same ones a few months ago and wrote them off because I was looking for something with more of a rake forward... like 1.5" front and 1" rear. You know? Yeah, I remember now I was looking into the H&R springs but was having a hard time with those too. I'm all over the place man. :mad:
AlpineAde
Post Fri Nov 30, 2007 4:47 pm
you found them?
Excellent!
frankiej
Post Fri Nov 30, 2007 4:52 pm
Yeah, thanks again :wink:
