i have tried on a few e30's to succesfully remove these without snapping the bolts. i have never succeded. i dont fancy using a blow torch right next to fuel pipes either.
Is there any tricks of the trade i should know about before i attempt to do them on another e30?
Sam
Underside fuel pipe clips
i have tried a impact driver on one...i didnt smack it with a hammer
i just put very firm pressure on it.
so maybe i will try your technique in future.
how would you suggest removing a snapped of bolt?
drill and tap?
drill and tap?
ian332isport
- Contact:
I personally had no trouble removing mine, but I can see that they would be a pig to sort out once snapped.
You basically have an internally threaded tube welded to the bottom of the car. It would be very hard to drill out, or salvage the tube. Grinding off the damaged tube and using either a self tapper, or a bolt passed down from the inside of the car are probably the only options. Neither very nice though.
Ian.
Ian.
ian now you have said that to me it has just occured to me. i ordered all the parts needed for that from bmw some months ago, and i had these little bits left over..i couldnt figure out what they were for. it has now occured to me that they are replacment tube's! not the sort of bit you would expect to get as a replacemtn part. they came in the same bag as the new screws.
Nice one
Nice one
Dude them screws are as hard as coffin nails being stainless had to cut grooves into the heads with a dremel and use a large flat blade screwdriver,wd40 and a lot swearing seized solid they were only snapped 1 left the tube in place and bonded the plastic pie clip on with some epoxy
- anisotropy
I had to cut out the wings of the clips and then cut flats on the edges of the screw head with a dremel so I could put vice-grips on them. Pain in the arse
ian332isport
- Contact:
My tubes are welded to the bottom of the car. I believe the earlier cars may have been separate, but not sure how they would attach.sam325is wrote:ian now you have said that to me it has just occured to me. i ordered all the parts needed for that from bmw some months ago, and i had these little bits left over..i couldnt figure out what they were for. it has now occured to me that they are replacment tube's! not the sort of bit you would expect to get as a replacemtn part. they came in the same bag as the new screws.
Nice one
Ian.
Gwynleym10
- Contact:
I had issues with mine...
Ended up drilling through the floor on some of them and put a bolt through. If you do this make sure you put loads of selant / anti-rust
