Heads up Display possible or not - you decide
StriderDriver
Wed Nov 21, 2007 12:33 am
please excuse this drunken moment of (in)sanity:
With all the technicians, engineers & mechanical know-how which is spread across this board, I've always wandered how possible it would be to create a HUD.
I am neither of the for-mentioned above, however I have thought that with electronic speedo's and tachometers something modern can be achieved with a retro E30.
I have no way of achieving nor implementing this idea, but I've often wandered if it could be a possibility. There are computer keyboards which can spread an image across any hard surface, so why not use the info presented to the dash in a heads up display?
Richyb
Wed Nov 21, 2007 1:04 am
Its easy to do and you can buy one off the shelf. Defi do them. Here's a direct link to the actualy HUD by Defi
http://www.egauges.com/vdo_grou.asp?Series=VSD_Concept
This ofcourse assuming E30's run a pulse signal for the speedo/tacho and not mechnaical
Wed Nov 21, 2007 1:19 am
e30's use an electrical signal for the speedo yes
Richyb
Wed Nov 21, 2007 1:20 am
Defi's HUD system will work then. They are very cool bits of kit, though not cheap.
**BANNED**
Thu Nov 22, 2007 1:46 pm
This sorts the problem of where you mount oil pressure/temp! Anyone using one?
Youth is wasted on the young.
Richyb
Thu Nov 22, 2007 11:16 pm
Not yet but I will be. A mate of mine has one in his CR-X and its pretty cool. Very clear even during the day too.
