MPG from M52
ste
Post Mon Nov 19, 2007 5:33 pm
I've just worked out my MPG and the best I've ever got from a tank is 23.70 since I fiited the M52. That was driving like a granny. More usual usage is 19 MPG. 8O
This is no better, if not worse than an M20 boat anchor. My old 2.7 M20 when running a MAF used to make circa 30MPG, so what's likely to be the cause?
I expected 30+ from this engine in this shell.
I'm guessing my gearing doesn't help - 3.25 dif and 215/40/16 tyres, but even considering that it seems pretty thirsty.
What MPG do E36 328s do?
tim_s
Post Mon Nov 19, 2007 5:44 pm
E36 328s do great MPG on the motorway, not so great around town. 35+mpg at 85mph set on the cruise control, 20-25mpg in town/traffic. 30mpg combined at a guess. 323 is pretty similar.
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
old_skool
Post Mon Nov 19, 2007 6:02 pm
Ste, I used to get high 20's from my 328i touring. That was a bit of a lardass compared to your racer too. Mine was standard with normal M52 manfolds and circa 60k miles.
Did you get the AFR's done when it was on the dyno, wouldn't that help to know at all? Only guessing but they would show whether it was running rich or not?
Post Mon Nov 19, 2007 6:20 pm
i used to get average 33mpg out of my e36 328i..
im getting 19mpg out of my 735i auto round town, so summat is up there!!
old_skool
Post Mon Nov 19, 2007 7:13 pm
My S50B30 is getting around 26mpg on my 3.15 and 205/55/15's with varied driving.
Jhonno wrote: im getting 19mpg out of my 735i auto round town, so summat is up there!!
Awesome!
JungleGus
Post Mon Nov 19, 2007 9:27 pm
maybe not being rechipped yet for the new manifolds?
interesting, i would have expected better too!
ste
Post Mon Nov 19, 2007 9:42 pm
Very interesting chaps - I do know it needs a remap, hopefully that will help.
old_skool_2002 wrote: Did you get the AFR's done when it was on the dyno, wouldn't that help to know at all? Only guessing but they would show whether it was running rich or not?
Unfortunately not, this is the only graph I have: http://www.e3024v.com/board/index.php?topic=111.0
(Add your graph to the thread too please Dameon if you get a second :D ).
gareth
Post Mon Nov 19, 2007 10:58 pm
that's about the same as i'm getting with my boat anchor! 8O
my wifes M50B25 E34 sport used to get 22/25mpg when spanked round town
not something obvious like a leaky tank / filler is it? :P
ste
Post Tue Nov 20, 2007 12:17 pm
Tank is brand new. Checked it all again at the weekend and it doesn't seem to be leaking at all...
abelai
Post Tue Nov 20, 2007 12:39 pm
Temp sensor or lambda? But don't forget that the e36 325i has the worst fuel economy in the e36 range it's worse than the m3 on the motorway and almost as bad round town. Mine other car is an E36 323i coupe my girlfriend use's that on the 50/60 roads and does 100 miles a day that averages 38mpg but when I drive it round town I get about 25mpg not much better than my sport.
If I can't fix it I'll f**k it up so bad nobody can!!
ste
Post Tue Nov 20, 2007 1:11 pm
May be temp sensor or Lambda, I get no errors from Carsoft though...
Mine's an M52b28 BTW - from an e38 328i. I did used to own an E35 525i with the M50b25 and to be honest didn't ever find it thirsty.
Post Tue Nov 20, 2007 5:41 pm
e36 328i or e38 728i ste :P
gareth
Post Tue Nov 20, 2007 10:31 pm
e35 525i :mad: :D having a bad day ste?!
ste
Post Wed Nov 21, 2007 12:40 pm
LMAO! You know what I meant. :D
Teach me to try to concentrate on work at the same time as posting.
Post Thu Nov 22, 2007 7:28 pm
I can get over 30mpg with my M50 ste, im getting 30 regulary at the moment with all the motorway driving im doing, even breaking the speed limit when conditions allow! :D
Around town is crap though, I expect little over 20mpg especially with the cold/damp weather and 'challenging' corners winkeye
brian325i
Post Fri Nov 23, 2007 6:37 pm
i always get between 35-40 miles for ten euro,work it out if you like,not sure what mpg it is,used get same in my e36 325.i presume ill get 30miles to ten euro when s50 goes in,if it ever does
S50 is alive :-)
ste
Post Fri Dec 07, 2007 3:35 pm
Update - spent some time fiddling with the fuel hoses and think I had a weeping one after my tank was replaced and one wasn't nipped up fully (the main feed from the fuel pump). TIghtened it and am now getting 30MPG in mixed B road driving.
So much better on the wallet! :D
gareth
Post Fri Dec 07, 2007 10:56 pm
gareth wrote:not something obvious like a leaky tank / filler is it? :P
winkeye uncanny! :D
it's always the simple things that are overlooked that'll come back to bite you in the arse! :D
Andy335Touring
Post Sat Dec 08, 2007 8:03 pm
winkeye uncanny! :D
In other words LOL !
Told you so, ner, ner ! :lol:
gareth
Post Sat Dec 08, 2007 8:26 pm
yep! :D
i wouldn't be that harsh myself though winkeye :D
