316/m10 gearbox advice
loggyboy
Tue Nov 20, 2007 1:51 pm
No matter how hard i tug or wiggle my knob it wont come... out of 1st
8O
anyway, is it worth looking at repairing the box (diy) or would it be easier fitting another one?
What gearboxes will suit and from what other e30s? doesnt have to be spot on ratios, just make it run.
What sort of effort is require to swap the box, im a compotent diy mechanic but what sort of time scales and any specilist/odd tools needed?
lance1a
South African/Scottish import
Tue Nov 20, 2007 9:09 pm
I had a look into this when considering engine swaps, as far as I can remember, the M40/M42 box should fit as will the dogleg from an E21 or 2002Ti/Tii. Not sure about the mounting points though.
BMW E28 528i X2
Merc W126 300E twin turbo
Merc cosworth 190e 2.3-16
BMW E28 525E
BMW E28 M535i
Saab 900 Classic Turbo
BMW E24 Highline Cosmos
BMW E24 Highline silver
BMW E24 Macau Msport
BMW 1972 2002
BMW E36 Alpina B3 3.2 Switchtronic
Renault
loggyboy
Wed Nov 21, 2007 11:30 am
Thanks. :D
Any1 got any other info?
Martinaston
Wed Nov 21, 2007 11:45 am
If you have worn engine and gearbox mounts the whole engine can shift forward causing the rear gearstick linkage to jump out of its mount, that then jams the gearstick in place. So you may not need a new box, get underneath it and have a look at the mount just behind the gearstick above the propshaft.
If you have a small mirror it will come in handy.
There is NO nucleus.
loggyboy
Wed Nov 21, 2007 3:35 pm
