LSD was a factory option, very weird as it has the small case! 3.45 fyi. I'm hoping to get the car done by my birthday (1st march), registered a little later, so I would definitely be up for a cruise or just so I can check out someone else's e30! Are they 17's spikuzi?
Engine + Body Wiring loom are across, just have to re-plug everything and do the interior, cooling system, fuel pump and lines, clutch slave, re-wire check control (didn't want to cut the interior to swap), swap the racks (to manual), install an immobiliser, ...the list goes on!
