320i 1990 auto touring
New bits:
dizzy and rotor, plugs, air intake hose, air filter, water pump, cambelt and tensioner.
Symptoms:
Originally the problem was a slightly high idle, and slightly hard starting (hunting, and needing the pedal applied to overcome a misfire and get the revs to 1500 or so; half a minute of this and it could be left to a 1200 stone-cold idle, dropping to just under 1000).
But now, car turns over, tries to fire, sometimes catches a bit, engine shaking, but doesn't take - try this half a dozen times or so, under ten secs each, and battery noticeably drains. Had to get AA twice now - first time they applied battery booster, floored the pedal, and it eventually fired up (diagnosis: dizzy/rotor, so changed them, they were very worn).
Second time, batteyr booster didn't work, so AA bod took out the crank position sensor, gave it a rub with some sand paper, popped it back and it eventually started (diagnosis: crank sensor).
When running the car is fine, sprightly even, with the new dizzy. If I was being picky, I'd say there was a very very slight hesitation on pick-up off the line when still coldish; a very slight murmering misfire at idle (barely noticeable and the idle is still only just under 1000 in neutral (800 when in gear), though on a restart when warm it sometimes sits at 800 in neutral.
I don't see how the CPS can be shot if it runs so well when actually going - but should this be my first suspect?
I've noticed two other things: The car starts easier if it's been parked in a garage. The inside of one of the plug caps looks white (stained, almost like a coolant stain) compared to the others, though the plug was no different when I swapped it.
any clues would be appreciated
thanks
