ok when i put my engine back in a few weeks ago, i went to bleed the coolant and found my heater wasnt working at all fan not even turning
so i bypassed the matrix to bleed the engine
anyway wanna get it sorted and how it should be,
when i turn heater on nothing happens except for a slight click sound coming from behind the das?
any ideas??
cheers
Daz
slight click from matrix?
www.oldskoolfantasy.co.uk
kam-325i
- Contact:
The click from behind the dash/glove box area should be the heater valve.
at the moment the matrix is bypassed
but did double check at the time
theres just nothing when you turn the heater at all no motor spinning etc
had a very similar thing with mine
if with the heater on (but not spinning) in the dark do the lights slighly dim as you hear the click sound
if so its the heater motor draining the power.
disconnect the fuse for the heater and you will confirm this if there is no click
HTH
HTH
Don't you wish there were a knob on the TV to turn up the intelligence? There's one marked 'Brightness', but it doesn't work.
- Brianmoooore
Heater is the bit that gets hot. FAN is not the heater!
As chief says. Not uncommon for the motor to seize after twenty years of no lubrication.
