Thu Nov 15, 2007 10:09 am
I did both of mine not so long ago....... not too bad......getting to the bolts from above can be abit trick especially if the engine has moved a lot.......... as said you will probably need another person to wiggle the engine about as you lower it back down so it sits correctly!
'88 DiamondSchwartz 325i tourer
SOLD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
