Advice with spraying mirrors
Rkive
Post Mon Oct 29, 2007 3:52 pm
Just sprayed my m3 style mirrors and was wondering if they need laquer on them, if so which laquer would be ok for bmw paint?
FWD is for Pussy's
Rkive
Post Mon Oct 29, 2007 6:04 pm
Someone must know
FWD is for Pussy's
Chris-W
Post Mon Oct 29, 2007 6:09 pm
Is it a metallic? Doesn't need lacquer if not. IIRC BMW aerosol paint is cellulose, so any motor factor / Halfords lacquer will do the trick.
Although if you got the paint from BMW you'd have got a can of clear coat as well?
Rkive
Post Mon Oct 29, 2007 6:19 pm
It isn't metallic it is atlantis blue, and it is from bmw but I didnt recieve clear coat.
So your saying it will be fine without laquer?
If it is ok without laquer how can I get a decent shine to match the car?
FWD is for Pussy's
Chris-W
Post Mon Oct 29, 2007 6:22 pm
Suggest leaving the paint to cure for a while and then taking it back with a 2000 grit paper then polishing it back up.
HairyScreech
Post Mon Oct 29, 2007 7:32 pm
that or hit it with a polishing mop.
