Is the throttle body fitted to the Alpina C2 the same as a 325 one? Or were these changed along with the engine at time of conversion?
Any ideas?
Alpina Throttle Body
davrosbeemer
rickk
Well, at least they've seemed to have supplied one for the C2 2.5, check out the (german) catalog:
http://www.behindmatrix.com/e30/fotost/f01118/tkc1.pdf
M5pilot
Exactly the same.
davrosbeemer
Thanks for the replies. My German isn't so good but thats quite a good PDF.
I have a throttle body on the way that was off an Alpina
. I guessed it was probably the same as a 325 but heh ho, I can tell my mates its Alpina spec! LOL
davrosbeemer
I received this today and after looking at it and flicking through some threads on here I reckon I should drill out an extra hole for my second vacuum pipe. There is already a hole for it but it does not go right through to the internal chamber.
Any thoughts?
Any thoughts?
alpina527
I can supply you with a bog bore version at Ԛ£120 exchange. mail alpina527@aol.com
