Disabling ABS
Jeff_200
Post Mon May 23, 2005 12:36 pm
Can anyone tell me how to switch the ABS off? I can't find a fuse to pull. :roll:
As I'm here, any thoughts on the problem would be appreciated :D
At speeds under about 5mph one of the sensors seems to think a wheel is locked, which fires the ABS. This is annoying and lengthens the braking distance but it also causes all sorts of worrying noises. Sometimes the ABS warning light comes on (usually only when the car is cold oddly) and if it does, the problem goes away. Although this obviously means I have no ABS, the car is a lot nicer (and over all safer) to drive like this than it is with the ABS going loopy.
I'll get the ABS checked but in the mean time, how do I deactivate it?
Thoughts appreciated please E30 gurus :D
TOURINGDADDY
Post Mon May 23, 2005 12:38 pm
Find the big silver abs ecu and pull the multi plug out and u got ur self a weeeeeeee bit
Jeff_200
Post Mon May 23, 2005 2:20 pm
Cheers. Where can the big silver abs ecu usually be found on what was a 325i Touring? :)
TOURINGDADDY
Post Mon May 23, 2005 2:28 pm
Usally in the passanger side foot well behind the glove box
Jeff_200
Post Mon May 23, 2005 4:27 pm
Much obliged :D
Jon_Bmw
Dangerous when thinking
Post Mon May 23, 2005 10:28 pm
Jeff_200 wrote:Can anyone tell me how to switch the ABS off? I can't find a fuse to pull. :roll:
Exactly how i described the problem to someone on here about 3 months ago, check the resistance of the two front abs sensors. They should be the same, if not replace one. I can't remember which way it is, whether they should have high or low resistance. Do a search on here.
Definatly sounds like a sensor to me, exactly the same symptoms as mine. Good luck
Post Mon May 23, 2005 10:42 pm
Sensors should have a DC resistance of just under 1000 ohms.
aauser
Post Mon May 23, 2005 11:55 pm
Also, neither of the pins on the sensor should go to earth, so check this too!
Jeff_200
Post Tue May 24, 2005 9:43 am
Cheers for the replies. I've pulled the plug out of the ABS ECU and the problem has effectively gone away. Just need to fix the root cause now so I can plug the ABS back in :)
calder
Post Tue May 24, 2005 10:17 am
another disable option is to pull out the abs relay. This is the silver cased relay that is stuck under the dash behind the glovebox next to the abs controller.
