car seems lower at one side that the other
was checking my car over as the mot is due next month ,
at the rear the suspension is lower at one side than the other on the passenger side i can get 2 fingers between the arch and the top of the wheel and on the drivers side i cant get any in .The top of the wheel sits level with the arch
Any ideas anyone ??
Any ideas anyone ??
ian332isport
- Contact:
Fat passengers
LOL i was going to suggest that but thought i would be nice for onceian332isport wrote:Fat passengers
will be back in an E30 oneday soon !
THE BMW 3-SERIES. IT'S WHY SOME ENTHUSIASTS ARE MORE ENTHUSIASTIC,
- orangecurry
I saw this on a cabbie - we swopped the springs, then bought new springs - but with absolutely no difference.
Then we noticed that there had been some (well repaired) accident damage in the rear corner where the side of the car was 'too high'.
Look carefully down the sides from standing behind the car - can you see any ripple/twist directly above the rear wheel arch (on either side of the car)?
An off-centre rear impact can twist a cabbie just enough to have this effect on the rear suspension.
Have either of you got hard-tops? (edited - Hyperion have you got a Baur?) My hardtop would not fit onto the 'twisted' cabbie.... it would either fit into the sockets at the back or it would fasten onto the windscreen.... it wouldn't do both
ok thanks for the advise
im not fat so that rules that out .
but the car has had accident damage which i was aware of when i bought it but ive been all round the car inside and out and underneath and cant see where its been damaged/repaired so im guessing it was a good job -and it was in 1991 so the previous owner didnt know what the damage was -but its definately been damaged as it shows up on the hpi report .
Have never fitted a hard top although the car is hard top prepared
Is the height difference a mot failure ?
- orangecurry
it wasn't noticed on the single MOT we did on the 'twisted' car. I doubt any MOTer will notice.
If you can borrow a hard-top for 5 minutes this might show you for sure.
If you haven't already, pull the side-carpets out in the boot and have a good look if you are worried.
ian332isport
- Contact:
Not on any E30 I've ever seensam325is wrote:this is an extremely common issue. do a search on it and apparently there is a 19mm adjustment bolt on either side at the rear. adjusting these bolts sorts it ......................apparently!
I had this problem on the front, thought that when i swapped the springs i'd accidentally put the one of the old springs back on by mistake...
Changed the wheels and tyres and it was fine. Think I was running 1x 14 and 1x 15 and I'd never noticed
i have the same problem with mine at the moment and its pretty low so its more noticable and it passed the mot fine last month.i'm planning on doing the rear bushes (one day) so hope this will sort it
89 325i touring
a guy i know has a motorsprt cab and hes has had all rear end bushes replaced.The problem is still there. i wasnt to sure about the bold either ian thats why i said apparently lol but lots of e30's have a problem where one side is a little higher than the other on the back.....it is often a very small amount but it is often there....as people say..probly worn bushes
