how to tell its a LSD
Ziggy
The "s" is on the tag with the ratio, rather than on the case itself...
There's a few other ways of telling, but the easiest is to park with one rear wheel on some grass at the side of the road, & try & pull away fastish... If it spins & goes nowhere it's a normal diff, LSD'll get traction from the other wheel.
Or jack up the back of the car, turn one wheel, & if the other goes the other way it's a normal diff. same way's an LSD.
A1BMW325iSport
- Contact:
my mate has a diff i went and looked at it has the S on the plate, but the output shafts move as above does that mean its def not an lsd then?dc wrote:turn the prop flange at the front,if the 2 output flanges turn in the same direction then its a lsd.if they turn in opposite directions the its a boat anchor.
A1BMW325iSport
- Contact:
the diff is one he bought, he reckons its an lsd, it has the S 3.91 on the plate
