A while back when i started my Superchager conversion i bought this adaptor plate from a bloke on a ebay who had made it for his IS.
The adaptor is a one peice item machined using a state of the art CNC milling Machine and machined from solid billet ally.
love the detail in the ports going from round to oval!!
I did try and sell the adaptor and trumpets but no intrest so ive decided to build it up as a project with the idea to sell the hole lot at the end as a running set up, or i might just keep them who knows.
any way some pics to start with
Heres the throttle bodys from an early hayabusa.
One problem with the throttle bodies i bought was the ebay ad never side they had a one bent butterfly, but it should bend back ok and they are all individualy able to be adjusted.
Started off by splitting the TB's and sitting them on the adaptor plate to measure the distence i need to split them and make up some spacers
Love how they look already!
Just need to get these little tabs extended there used to balance each butterfly and are to short now ive spaced the TB's differently!
The injectors are Peco ones i beleive and was just woundering if they would be ok to use as is far as i know bosch type dont fit!
I've also sold a second incorect set i bought to my freind who has a MK2 golf
