best thing for removing glue from paintwork
oakey
Post Thu Oct 11, 2007 12:04 pm
I have a wing with the glue from some Ducktape left on it. Any advice as to what products are good for removing it?
StuBeeDoo
Post Thu Oct 11, 2007 12:05 pm
Tar & Glue Remover??
HartgeH27
Post Thu Oct 11, 2007 12:17 pm
hairdryer - heat - rub
oakey
Post Thu Oct 11, 2007 12:23 pm
HartgeH27 wrote:hairdryer - heat - rub
Rub with what matey?
Turbo-Brown
Boost Junkie
Post Thu Oct 11, 2007 12:39 pm
WD40 and a bit of soft cloth should do the trick :)
aceraf
Post Thu Oct 11, 2007 11:10 pm
Get some panel wipe, also known as panel degreasant. It's used by bodyshops and it removes most stuff from paint without removing the paint. Any good paint supplier should stock it.
Breaking 325i Touring
d6dph
Post Fri Oct 12, 2007 7:20 am
Autoglym intensive tar remover, put some on a tissue, leave on glue to soak for 5-10 mins. wipe clean
oakey
Post Fri Oct 12, 2007 4:49 pm
Thanks for all the ideas lads!
I used Mykal sticky stuff remover- worked a treat. 5minute job and there was glue all the way along the wing :D
Apparently citric acid is what all these tar/glue removal products contain, so in theory some lemon juice would probably do the trick also :wink:
Post Fri Oct 12, 2007 7:48 pm
pretty good wing now for a tenner eh :wink:
oakey
Post Fri Oct 12, 2007 7:52 pm
Simon13 wrote:pretty good wing now for a tenner eh :wink:
Fekkin HELL yes!
Nice one Simon :D Its in better condition than the rest of my car!
fuzzy
He who sleeps with "Gingers"
Post Fri Oct 12, 2007 8:01 pm
oakey wrote:I have a wing with the glue from some Ducktape left on it. Any advice as to what products are good for removing it?
thinners and some 80 grit sandpaper should remove it i think.
or perhaps maybe some autoglym intensive tar remover.
maxfield
Post Fri Oct 12, 2007 8:03 pm
80 grit and thinners! Bye bye paint :)
Dave's idea sounds good, he knows his shit when it comes to paint work.
fuzzy
Post Fri Oct 12, 2007 8:08 pm
maxfield wrote:80 grit and thinners! Bye bye paint :)
no one mentioned saving the paint just something thats good for removing glue. :D
