which diff?????
udp260y
Wed Oct 10, 2007 3:04 pm
hi guys
i am about to exchange auto box for a 5 speed getrag box and i have the prop and diff from the manual donor car. Would you advise using the diff from the manual or will the auto offer better ratios?
cheers in anticipation[/b]
hongkongfuey
Mad-tango-geezer
Wed Oct 10, 2007 3:34 pm
what car you got , what ratio is the diff on the car , what ratio is the donor
with cars like mine,
udp260y
Wed Oct 10, 2007 4:22 pm
hi, its a 323i auto and the donor gearbox is from a 323i same year, 1983.
dannyboy759
Wed Oct 10, 2007 5:12 pm
There are a few ratios for the 323, but as a rule if you use the auto diff for a manual car it will be geared to high,
i.e. the 325 has a manual ratio or 3.91 but the auto is 3.64, great for fuel but the 3.91 obviously make sthe car faster.
udp260y
Thu Oct 11, 2007 4:32 pm
My spanner man hasnt done one on an e30 before, is it fairly straight forward swap. auto to manual?
