my engine is pinking in 3-4......help
jonnyboy
Post Fri Oct 05, 2007 11:30 pm
hi im haveing a problem with my car pinking in third and fourth gear when on boost its runing 4psi at the mo. i was told to change the fuel pressure but i dont now what to can u guys help chears. :cry:
fowler
Boost Junkie
Post Fri Oct 05, 2007 11:46 pm
what mapping are you using more info required ??
EX A-Tech Workshop bitch !!!
gone but not forgotten
jonnyboy
Post Sat Oct 06, 2007 1:04 am
at the mo am using the stock airflow meter which is crap i know :roll: . i wana use megasquart but am not sure how to go about using it or where to get it from or price of it. ive got a t34 turbo which runs mint at 4psi apart from the pinking in 3 and 4th gear at high revs ive put a 3.0 fuel regular which helps alot. cheers any help will be mint. i will try and post some picture asoon as ive got my camra working. :)
Kos
Post Sat Oct 06, 2007 1:06 am
what type of actane fuel are you using ?
how long has it been running with the turbo ?
has it happened before ?
www.pukardesigns.com
IG Pukar.Designs
appletree
Post Sat Oct 06, 2007 3:22 pm
Also has it been like that since you put the turbo on or has it got worse as youve been using it?? :(
Colonel Sanders
Le Surrender Monkey.
Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
Post Sat Oct 06, 2007 6:03 pm
have you played with the timing?
jonnyboy
Post Sat Oct 06, 2007 8:21 pm
hi, its been like it from day one ive not played with the timing so set at standed settings and am using super unleaded. i turboed a 320i and am moreless using the same set up and it pull like a train so dont know why am having problems with this 1
Ant
Retired Team Member
Retired Team Member
Post Sun Oct 07, 2007 3:23 pm
the pinking is either a mix thats too lean, or too rich, too much timing at peak torque( my bet given the high gears only situation as you've posted) or any combination of the above
a turbo will increas the effective CR of any engine, thats how the power gain is achieved so a std 8.8:1 CR M20B25K engine will have an effective CR of 11:1 or so @ the given boost level, too high for the stock timing map in any case.
Control is the key, and TBH at the moment you have none.
where is the AFM placed ? suck through or blow through ??
jonnyboy
Post Sun Oct 07, 2007 9:01 pm
hi,cheers for your reply . the afm is on the end of the turbo so it will be suck through.u said about the timing,do you know wat setting it will need to be set at.cheers
Gunni
Post Sun Oct 07, 2007 9:52 pm
#1 Check your AFR
#2 Find a way to retard timing if needed when you have rectified the lean AFR.
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
