Car wont go past 5000 rpm
Mike318i
Fri Jan 21, 2005 6:01 pm
I have a problem, My car will not go past 5000 rpm, it wants to but its like something is stopping it.
I changed the Leads, plugs, Dizzy cap, Rotor arm.
Any help would be very much appreciated :wink:
1990 318iS Having a new engine ----1990 325i SE weekend ride
Ant
Retired Team Member
Retired Team Member
Fri Jan 21, 2005 6:07 pm
air or fuel starvation perhaps dude ??
new filters for both aint gonna break the bank so worth a shot, then if still no good I suspect a duff TPS not sending the WOT signal to the ECU,
Keep us posted Mike :cool:
magnumlove
Fri Jan 21, 2005 6:27 pm
That happened on my 316i and i was informed that it was more than likely a worn cam. Apparently its a common problem with the m40 engine?
Mike318i
Fri Jan 21, 2005 6:30 pm
Cheers for the advice Ant :cool:
:eek: Hope its not a worn cam
I was also thinking it maybe an airflow meter problem?
Paul325i
Fri Jan 21, 2005 6:31 pm
Cam's knackered as above, you need to replace it, probably do the tappets and the oil spray bar at the same time.
magnumlove
Fri Jan 21, 2005 6:35 pm
Mike318i
Fri Jan 21, 2005 6:37 pm
Is that an expensive job to do paul?
Paul325i
Fri Jan 21, 2005 6:40 pm
Not vastly, you can pick up the parts in GSF to.
Mike318i
Fri Jan 21, 2005 7:13 pm
magnumlove wrote:have a look at this mate
http://www.bmwe30.net/cgi-bin/datacgi/d ... Section=08
Thanks for that mate, it looks like a new cam :eek:
Ant
Retired Team Member
Retired Team Member
Fri Jan 21, 2005 7:16 pm
do the filters first Mike, you never know, I've fixed "head gaskets" on M62 engines with a new thermostat before
dont give up till all the options are exhausted !
Mike318i
Fri Jan 21, 2005 7:26 pm
Yes mate i will do, Im going down GSF tommorow morning to buy the filters, I have a 318i Touring aswell so i might swap a few bits over to see if any differences are made.
Another thing is that the cars fine from cold?
johnl320
Fri Jan 21, 2005 7:48 pm
you take your car to 5000 rpm from cold??
Mike318i
Fri Jan 21, 2005 7:51 pm
johnl320 wrote:you take your car to 5000 rpm from cold??
Nah mate, only on this occasion to check when it does it. i dont ever take my car past 3000 rpm from cold.
welshmark
Sat Jan 22, 2005 5:44 pm
hi does any one know rough price for this job my 316i been like that for a while and i have changed every thing as well my next call was may be a fault with the fuel pump as now and aagain it seem to loose all power and goes down to about 5 mile an hour before picking up speed again. allways on the m6 as well.
Demlotcrew
Sat Jan 22, 2005 6:07 pm
I would say something like Ԛ£500 all in with parts from GSF and ECP
Andrew
Sat Jan 22, 2005 6:18 pm
Isn't the sign of a worn camshaft mean the car won't rev past 5k in 2nd and 3rd gear? For M40's engines
Ant
Retired Team Member
Retired Team Member
Sat Jan 22, 2005 6:24 pm
:offtopic:
Simon did Scott make to you OK ?
Sat Jan 22, 2005 6:39 pm
yes mate he did! Rims look a state but will look great refurbed! Is that welded one straight? can't decide what colour, polish etc when i get them done. suggestions? He moaned it was a hard place to find!
breitlingboy
Sun Jan 23, 2005 1:57 pm
I've got similar symptoms on my M20, is it common on these engines too?
Sun Jan 23, 2005 2:10 pm
If the engine is fine when cold, isn't it about time someone mentioned the ECU water temp sensor?
Mike318i
Sun Jan 23, 2005 5:10 pm
I thought a worn camhaft would make a noise? it seems strange why it works fine from cold,
Sun Jan 23, 2005 6:40 pm
Check the airflow meter.. It could be the temp sensor - its at the front of the meter
Does the point in the rev range that it do it change with temperature?
Demlotcrew
Sun Jan 23, 2005 7:28 pm
Okay do this, when the car is warmed up drive it in second right to 5k till it wont go futher, then change to third if the car has a momentary loss of power i can tell you exactly what it is.
Andrew
Mike318i
Sun Jan 23, 2005 7:43 pm
Demlotcrew wrote:Okay do this, when the car is warmed up drive it in second right to 5k till it wont go futher, then change to third if the car has a momentary loss of power i can tell you exactly what it is.
Andrew
Thats exacly what its doing
mike
Demlotcrew
Sun Jan 23, 2005 7:46 pm
Cam/rockers/tappets are gone for sure 100%
Mike318i
Sun Jan 23, 2005 7:49 pm
I might aswell drop a another engine it in
Demlotcrew
Sun Jan 23, 2005 7:52 pm
Yes a good M20 can be had for little money. The M40 is good engine for its time, but its not worth fixing. Get a M42 in there its much better but you might find that it will cost you alot more than getting a M20 in.
andrew
Mike318i
Sun Jan 23, 2005 7:58 pm
Yer a m20 would be nice, but i need to keep it standard due to insurance costs, So another m40 it is, or just the head
Sun Jan 23, 2005 8:01 pm
318is are only one insurance group higher than an 318i, but as Demlot says the engines cost more to buy than an M20
