How does a coolant level sensor work?!
Ziggy
Mine seems to have stopped working, so I was looking it it the other day & I can't actually see how it works! Maybe it's just something that's broken on mine but it's bugging me all the same! Anyone?
A1BMW325iSport
its a float with contacts inside,
the terminals inside are prob corroded hence why yours isn`t working
Ziggy
Just couldn't see any way the float was actually connected to anything! I guess that may have been the problem...!A1BMW325iSport wrote:its a float with contacts inside,
A1BMW325iSport
the connections are at the top inside you can`t see them without taking apart
Ziggy
Interesting! Didn't look all that carefully, but all I could see was the black plastic bit which appeared to have no way for the coolant to get inside, and a white floaty ring around it, that didn't appear to be connected to the black bit in any way!
There's a magnet built in to the float, and a small glass reed switch inside the middle column.
Water gets into the middle and corrodes the reed switch's leads.
There are two sorts of sensor available - one that fits plug upwards for inner wing mounted coolant resevoirs, and one that mounts plug downwards, which fits the resevoirs attached to the radiator. Get the wrong one and your coolant light will come on when the water is fine, and go off when it is empty.
Ziggy
Obvious; why didn't I think of that?!
Cheers Brian
Cheers Brian
