m50 engine mounts+parts
Scrotty
Post Fri Sep 21, 2007 2:18 pm
which e36 mounts are the correct ones to use?
i have a 318i e36 breaking...are those mounts any good for the job?
possibly dropping it in a 318iS e30 using machine single mass m20 flywheel, have servo&master from mk1 clio too and various rads from 525-535 e34's
what else would i need? would the prop need to be shortened?
cheers
CraigG
Post Sun Sep 23, 2007 2:58 pm
look in and read through the M50 developments thread, everything you need to know is in there. and its mucho helpful.
m-dtech
Unapproved Trader caution
Post Fri Sep 28, 2007 10:01 pm
e36 320i or 325i m50 engine mounts.
i used the e30 318is gearbox
i also used the standard flywheel from the m50 engine.
propshaft was e30 m20b25 which is shorter than the 4pot props.
manifolds from e36 328i
i have the lot for sale :D
